plug wire clips
Old Jul 16, 2006 | 05:40 PM
eigenvector's Avatar
eigenvector
plug wire clips
This might sound like a dumb question, but how exactly do you get the cable ties for the spark plug wires open? I have a 2000 ranger 3.0 and for the life of me I can't figure it out. A diagram would be wonderful.
Old Jul 16, 2006 | 11:11 PM
RangerPilot's Avatar
RangerPilot
The cable ties? What in the world are you talking about? Cables ties that I know of have one way to come off and that's cutting them.
RP
Zach
Old Jul 16, 2006 | 11:27 PM
eigenvector
The ties, that route the spark plug wires over and around the intake manifold, typically three wires for the first 2 clamps/ties/clasps/holders whatever you want to call them, then 2 for the next one, and finally a single wire through the last one and then onto the spark plug. They're just plastic deals that route the spark plug wires so that they keep out of the way and I would assume so that they don't get burned on the exhaust and intake manifolds.
It's a little too late for a pic of them, but you can't miss them, if you've ever had to change your wires you would have had to removed them first.
Old Jul 17, 2006 | 12:08 AM
RangerPilot
Oh yeah I've seen those, I have them as well, it's been forever since I did my plugs lemme go have a look.
Hmm...on my truck there are no cable ties or anything, they're just little press-in sorta clips, the wires just press into a clip that is roughly the size of the wire.
RP
Zach
Old Jul 17, 2006 | 05:34 AM
Dan Robertson's Avatar
Dan Robertson
If it is a cable tie, just cut it and replace it with a new one. Good luck, Dan
Old Jul 17, 2006 | 05:58 AM
FTE Trigger's Avatar
FTE Trigger
I think he's referring to the Press/clip In wire routers. The ones that come Standard w/ the stock Spark plug cabling set-ups from the factory. ...
Old Jul 17, 2006 | 09:01 AM
eigenvector
It doesn't sound like people leave those on after changing the plug wires.
But still, how do you open them? I'd like to keep mine, they keep the plug wires all nice and tidy
Old Jul 17, 2006 | 09:02 AM
rgbot's Avatar
rgbot
I just used a really short flat head screw driver and pried them open, worked for me.
Old Jul 17, 2006 | 09:07 AM
eigenvector
That's really the question, WHERE did you pry them? I know where the hinge is, but there are like 3 clips on the wire router and none of them are in the same general vincinity. Did you just basically rip it open with the screwdriver or is there some pressure point?
Old Jul 17, 2006 | 09:30 AM
rgbot's Avatar
rgbot
On the bottom of each one you may be able to see where they interlock, thats where I pried them apart. It is kind of a pain though. Let me know if this helps.
Old Jul 17, 2006 | 11:26 AM
RangerPilot
Anybody got a picture of these? That's definetly not what's on my truck.
RP
Zach
Old Jul 17, 2006 | 01:18 PM
eigenvector
RP
Zach
I'll try to post it when I get back home tonight. I honestly didn't think this would be such a big todo, but I guess threads take on a life of their own.
Old Jul 17, 2006 | 02:13 PM
RangerPilot
Haha everything can amuse us all to no end.
Like the performance debate between two of our members that ended up gettin' it's own thread lol.
RP
Zach
Old Jul 17, 2006 | 06:17 PM
eigenvector
That's what I'm talking about
Got two shots of them
Old Jul 17, 2006 | 10:36 PM
RangerPilot
Well ain't that spiffy...mine are just little holders mounted to the intake and valve covers, shaped and sized to match the plug wires.
RP
Zach
