Differentail oil question ???
Old Jul 16, 2006 | 04:45 PM
maevans's Avatar
maevans
Well it's time for myself to change the rear differential cover do to rusting,
My question is do i need to had friction modifer that ford sells if i use Mobil Synthetic 75w - 140. I've been told by others that i don't with Mobil Synthetic.
Any help would be great. Thanks.
Old Jul 16, 2006 | 05:23 PM
monsterbaby's Avatar
monsterbaby
well first question is do you have a limited slip diff? But to outright answer your question actually no you don't as the mobil 75w-140 has friction modifiers in it already according to thier info specifically for running it in limited slip diffs. I suppose they did that so people won't add other friction modifiers to thier gear oil that may not be compatable.
Old Jul 16, 2006 | 06:06 PM
maevans's Avatar
maevans
Yes - I have a C1 axle code that tells me it's a 3.73 limited slip.
Old Jul 16, 2006 | 08:36 PM
magnum300's Avatar
magnum300
from Mobils site
Mobil 1 Synthetic Gear Lube 75W-140 LS contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid.
Old Jul 16, 2006 | 08:40 PM
Lushman's Avatar
Lushman
After you addd the new differential fluid, drive in figure 8's. If there is chirpping going on you will need to add some kind of friction modifier. I used the Amsoil syntehtic and it was very obvious that I needed to add some of the modifier when I did any turns!
Old Jul 17, 2006 | 12:16 AM
BobbyDiesel71's Avatar
BobbyDiesel71
Do you have a Blaine's FARM n FLEET?
I bought Majestic75W-140 gear oil and bought the friction modifier for the rear LS 3:73 of my 2002
I have had no issues
Old Jul 17, 2006 | 03:38 PM
maevans's Avatar
maevans
No Blaine's FARM N FLEET, Just Tractor Supply Co. After i re-coop from today's heat, I will take a run over to TSC and do some looking and reading.
Old Jul 17, 2006 | 04:41 PM
Chance_Thomas's Avatar
Chance_Thomas
He has good pics and write ups
http://guzzle.rbmicro.com
Old Jul 17, 2006 | 05:12 PM
magnum300's Avatar
magnum300
When I did mine I put a Mag Hytec cover on it, going to be much easier to change the fluid next time
Old Jul 17, 2006 | 07:05 PM
maevans's Avatar
maevans
Mag Hytec was my first choice( $ 235.00 beans), But a upcoming Bear hunt as me spread pretty thin for anything that can wait, So i just got a stock one for $ 24.00 from the dealership, it will do fine until i can get the Mag-Hytec.
Old Jul 17, 2006 | 07:14 PM
PSNut's Avatar
PSNut
Ditto on the MAG-hytec unit...real nice.
BTW Mark, I believe ther's a TSB out that is saying to use the 75W-140 in the front diff. too.
Nut
Old Jul 17, 2006 | 08:31 PM
maevans's Avatar
maevans
Nut
Thanks for the heads up on the TSB .
Old Jul 17, 2006 | 10:22 PM
John7894's Avatar
John7894
Don't these trucks specifically require synthetic in the diffs? Any reason why?
Old Jul 18, 2006 | 04:26 AM
PSNut's Avatar
PSNut
Yes....it's a must to prevent diff failure.Synthetic has better thermal conductivity.
Nut
kawika
49
Jun 23, 2021 11:47 PM
changoo
2004 - 2008 F150
Dec 4, 2010 06:25 PM
mrad
Nov 6, 2009 12:52 AM
figurhead
Oct 16, 2009 02:46 PM
matt68
Oil & Lubrication
Mar 29, 2002 05:42 AM
