reflashed catch code?
Old Jul 16, 2006 | 01:16 PM
kbeefy's Avatar
kbeefy
I was told the dealer sometimes re-flashed pcm's during service, and a catch code might not be the same as what is on the PCM. If this is true, how do I gat the correct code?
I've searched the door jamb and under hood for a sticker, can't find one.
Thanks!
Old Jul 16, 2006 | 02:27 PM
Cuda_jim's Avatar
Cuda_jim
Found something here:
https://www.ford-trucks.com/forums/s...earchid=676502
cookie88 quoted:
It's the box code of your PCM (the computer). Look for a small white tag on the drivers side door post, A-pillar side, with a four digit code on it (XPC4, DAC3, etc.) if the tag is no longer there you will need to remove the PCM from the vehicle and find the code tag on the box.
Old Jul 16, 2006 | 03:26 PM
kbeefy's Avatar
kbeefy
yeah, I've already had my pcm out, got the code off of it (NVK4) and installed a chip. It didn't have any effect, and I'm trying to figure out why.
Old Jul 18, 2006 | 10:57 AM
kbeefy's Avatar
kbeefy
bump.. anyone?
Old Jul 18, 2006 | 01:04 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Whose chip? I find that weird. If you gave the programmer the proper code I would have to suspect the maunufacturer of the chip has done something incorrect. Mine worked like magic. The old chip died, I returned it along with the required amount of dinero and the code off of the PCM and viola!
Old Jul 19, 2006 | 12:30 AM
kbeefy's Avatar
kbeefy
it's a banks ottomind - powerpack chip. The programmer didn't require the code, it figured it ou ton it's own. That part was kinda a troubleshooting measure, to see if there was something else wrong with my truck or if it was just the chip. So far I've tried two different chips w/ the same results.
Old Jul 21, 2006 | 04:06 PM
fourwheeler88's Avatar
fourwheeler88
Make sure u clean the protective film off of the circuit board when u plug the chip into the pcm i had the same problem and it wasnt all off. it has to have full contact
Old Jul 23, 2006 | 01:37 PM
kbeefy's Avatar
kbeefy
I've had the computer out a total of 3 times cleaning the contacts... it's definatly clean enough.
redman84
Mar 8, 2011 11:28 AM
Automator
23
May 13, 2008 07:38 AM
biz4two
Modular V10 (6.8l)
Nov 19, 2005 10:31 AM
mjwhip2
Jan 18, 2005 12:18 PM
abendx
Computer Chips & Tuners
Nov 13, 2003 08:27 PM
