1969 E200 C4 auto
Old Jul 22, 1999 | 09:57 PM
Brian Stafford
Guest
Posts: n/a
1969 E200 C4 auto
My shift seal has gone out, is it hard to replace? Can anyone give instructions?
Old Jul 24, 1999 | 09:45 AM
deleontow's Avatar
deleontow
1969 E200 C4 auto
I assume you are speaking of the selector shaft seal, this is a small job to replace, you have to remove the pan, remove the valve body, remove the selector shaft, just to get to the seal. If you are not familar with removing valve body, I would look at a manuel before you try. If you decide to remove seal, be very carful when lowering the valve body, as you may have a ball or two come out, like a BB from a BB Gun, also make sure not dirt gets on the valve body, or it will cause problems later.
Dave
Old Jul 25, 1999 | 06:59 AM
StockMan's Avatar
StockMan
1969 E200 C4 auto
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
