cracked wheel
Old Jul 14, 2006 | 07:13 PM
helpfulguy's Avatar
helpfulguy
cracked wheel
FYI. if anybody else is running steel spoke rims keep an eye on them, coming back from austin i devoloped a bad vibration and i mean bad. Got to checking my tires figuring i slung a weight off and i found one of the spokes had a crack all the way though it. put the spare on and vibration went away. and to think i turned down a set of aluminum wheels because i thought the steel ones would hold up better.
Old Jul 14, 2006 | 09:22 PM
fishmanndotcom's Avatar
fishmanndotcom
geez! sounds like you just got a lemon of a steel wheel... never heard of a steelie doin this but have heard several accounts of alum wheels cracking/coming apart
you sure you werent jumping rocks out there in texas? i think you may have gotten tipsy one night and decided to show off to the local "coyote ugly's"
-cutts-
Old Jul 14, 2006 | 10:07 PM
DaBigTow's Avatar
DaBigTow
I've had two aftermarket steel replacement wheels bend on the front end. Ran them on the rear long enough to wear out the tires & threw then away. Also bent the OEM aluminums, but that was from hitting bumps on CA highways.
Old Jul 15, 2006 | 07:17 AM
helpfulguy's Avatar
helpfulguy
fishmann i passed that stage a long time ago. but the condition of the roads down here on the border are some of the worst in the country, worse than the LA area that i have been through. you should see the street in front of my house, we moved in a little over a year ago and their still working on it, it is currently dirt! but even with that i never expected to crack a steel wheel. but thats the way it goes.
good to doo
Dec 13, 2014 09:50 AM
BadDogKuzz
28
Nov 28, 2013 08:21 AM
reylings
Oct 23, 2012 08:32 PM
GMayer
1997 - 2003 F150
Jun 28, 2005 09:12 AM
