Sponsored by: Auxito
power seat installation
Old Jul 13, 2006 | 04:26 PM
hambone4x4's Avatar
hambone4x4
hello,
i am converting my truck from a manual seat to a power seat. it is a 99 f150xlt. there is a wire under the seat (looks like a seat belt sensor) but it is not a big enough connector for this application. i went to a local junk yard and found the connector to hard wire the seat, but there are alot of wires (8) and they are not as simple as red/black. is there anyone out there who has expirene in electrical that could give me instruction as to how to wire this seat??
thanks
Old Jul 13, 2006 | 07:58 PM
Ultramagdan's Avatar
Ultramagdan
Welcome to FTE!
You might need to do a little digging. The stock harness on your truck probably has the plug-in already installled on it. Finding it will be the next challenge. Your best bet may be to go back to the salvage yard and see how the wires run or to find a friend that has it and see how the wires run.
Old Jul 13, 2006 | 09:43 PM
emitchum's Avatar
emitchum
get an adaptor for the cigarette lighter and a couple of alligator clips. that is what i did for the short term and that was 3 months ago. let me know what you find, i need to finish the job someday
Old Jul 15, 2006 | 05:44 PM
Smaug's Avatar
Smaug
I just ran a pos from an accessory fuse block I already had wired in. Neg wire is grounded to one of the seat bolts.
Old Jul 18, 2006 | 05:16 AM
hambone4x4's Avatar
hambone4x4
i got it!! i jumped the wires behind the kick plate near the e-brake pedal. used a test light to find a hot wire when the key was turned on. thanks for the input folks.
vettman
Mar 23, 2015 07:29 PM
CdnWillyG
41
Feb 6, 2012 09:07 AM
splice1985
May 14, 2010 05:23 PM
jrg24
1983 - 2012 Ranger & B-Series
Oct 3, 2009 03:39 PM
