Springs?
Old Jul 13, 2006 | 07:51 AM
Bob Gervais's Avatar
Bob Gervais
Springs?
Well, it is apparent to me that I need to do some suspension work on the X. It's all stock now, with the exception of Edelbrock IAS shocks. They're OK, but I like the Bilsteins better and will be replacing them when I do the springs/swaybar/self fabricated traction bar install.
I've searched, and read a few threads regarding springs, but I'm a little confused. I want to install the pickup springs and get rid of the wimpy stockers, but what should I use? I do all my Ford parts shopping with Torrie at fastpartsnetwork.com (formerly fordpartsnetwork.com), and I need to supply him with part numbers, or spring codes if I can.
Need part #'s or spring codes for:
-front springs
-rear springs
Also need to know what u-bolts to use, if I should use the stock rear block or a different one, etc. Basically, whatever other parts are required aside from the springs.
I'm not interested in lifting the truck (though I know the truck springs will do that a little), but I am interested in having the truck a little higher in the rear than the front, as it is now. Nothing sucks worse than a nose-high truck!
Thanks in advance for any help!
Old Jul 13, 2006 | 03:36 PM
Monsta's Avatar
Monsta
Sit. Stay.
If you do a search for "Spring Code" you'll find a chart that will give you the nominal height gain as well as the "code". Actual part #'s are not listed.
You could always go for springs from an 00 F-250 X-cab, XLT diesel. (Not with the plow prep package. Those are X springs)
For the rear you can add the stock pickup pack w/o the helper or slide in an add-a-leaf in order to maintain rake. Or just pop in a 2" block. Probably a lot cheaper but you'll then have unmatching spring rates front & rear...FWIW.
Use the U-bolts from whatever application you are using the spring pack from. IOW, if you using the springs off the front of an F-250 use those (size) U-bolts. Don't reuse old U-bolts as they yield and cannot be reused in most cases.
Old Jul 14, 2006 | 03:23 AM
Stewart_H's Avatar
Stewart_H
Here is my thread regarding the same topic. However, in my thread I already had made up my mind on most of the components I wanted, and was asking for input from the members in the know.
Unfortunately, I only got a handful of responses. They were full of very good and useful info, but the thread didn't garner a whole lot of responses.
https://www.ford-trucks.com/forums/showthread.php?t=496665
The setup I finally decided on getting was V code fronts, B code backs, tapered block for the rear, Bilsteins all the way around, Hellwig Sway in the rear, and replace the steering stabilizer. I opted not to go with the air bags.
Here is info regarding the proper Bilsteins to use, if you choose to use the same springs as I've mentioned.
https://www.ford-trucks.com/forums/showthread.php?t=503337
If you decide on the same setup, here are the Ford part numbers:
V code: 2C3Z-5310-HA
B code: 3C3Z-5560-CB
Tapered block: F81Z-5598-FA
...and the Bilstein part numbers if you use the above springs:
Front: BE5-2818 (OEM length for the F250 4x4)
Rear: BE5-6209 (OEM length for the Excursion 4x4)
That's the route I decided to go.
Stewart
Old Jul 14, 2006 | 05:29 AM
Bob Gervais
Thanks for the info guys!
Stewart, how do you like the ride and handling of the truck now?
Old Jul 14, 2006 | 10:11 AM
Stewart_H's Avatar
Stewart_H
I've not actually installed them yet.
The springs are sitting in my garage and the shocks and sway bar are in my wifes kitchen (she absolutely LOVES that), and I still need to order the steering stabilizer.
I'm also at the mercy of my buddy's schedule because I have a bad back, so he does most of the heavy wrenching for me whenever we work on our trucks, and his days off differ from one week to the next.
I have however installed the AFE Stage 2 intake with Pro-Guard 7 filter!
That thing ROCKS!
Stewart
