Aerostar Ford Aerostar
bright lights.
Old Jul 12, 2006 | 10:36 PM
cbr900's Avatar
cbr900
Exclamation bright lights.
Hy guys, i have a strange problem on my 1991 4.0 v6 it seems that all the drivers side lights, headlamps, tail lights and indicaters are a lot brighter than the left side lamps and i cant find out why, i am thinking it maybe a bad ground on the left side lights but would that not effect the right side as well? any surgestions would be appreciated.
Cheers cbr900
Old Jul 13, 2006 | 06:40 PM
bertha66's Avatar
bertha66
Yes, it does sound like a ground problem, and I do think that they are side to side differant.
Old Jul 13, 2006 | 07:52 PM
cookkd's Avatar
cookkd
Cheers cbr900
G100 - Right side lighting - located top rear corner of RH fender apron, below hood hinge
G101 - Left side lighting - located Fron of LH fender apron, forward of starter relay
Old Jul 13, 2006 | 08:09 PM
Mormakil's Avatar
Mormakil
Do you have any more info? I'm not sure about one of my grounds, it's by exhaust manifold on passenger side, not sure of the factory grounding location.
M
Old Jul 13, 2006 | 08:53 PM
99f350sd's Avatar
99f350sd
I would check the bulbs first...
Dick
Old Jul 14, 2006 | 10:24 PM
eehoepp's Avatar
eehoepp
Dick
I'll second that suggestion. You may have an 1157-type bulb with the filaments shorted together.
Cheers,
Eric
Old Jul 15, 2006 | 02:45 PM
cbr900's Avatar
cbr900
thanks guys i will take a look at those bulbs and ground points.
cbr600f31997
Apr 11, 2014 05:11 PM
cbr900son
Oct 16, 2012 06:33 PM
cbr900
Aerostar
Mar 9, 2006 03:09 AM
cbr900
Aerostar
Mar 1, 2006 07:03 PM
James's f_1_fiddy01
3.8 & 4.2L V6
17
Dec 3, 2003 07:09 AM
