Found My Leak !
Old Jul 12, 2006 | 07:09 PM
marvinlong's Avatar
marvinlong
Found My Leak !
Just found the source of my boost leak. After looking up past my EGT probe to i guess would be the up-pipe. Soot all over the heat shield. Happy that i located it but un-happy as to how to get to it. Is this tied together with a gasket? Is this a DIY project or give it to a pro? By the looks of things i guess this to be 3/8 bolt? Need 2ft. ext w/wobble. Maybe you guys can add some cents to this dilemna!
Old Jul 12, 2006 | 07:52 PM
CanadaGuy's Avatar
CanadaGuy
The "published" procedure for removing those pipes involves removing the turbo. I find the drivers side pipe isn't all that bad to change without removing the tubo, as long as you can apply some heat on the bolts going into the turbo. I pull the transmission if it needs the passenger side one.
Old Jul 12, 2006 | 09:03 PM
marvinlong's Avatar
marvinlong
well, that doesn't sound good. probably will have to seek a professional mechanic on this one. thanks for the reply
Old Jul 12, 2006 | 09:08 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i would much rather pull the turbo out (4 hours for a newbie) than dropping the transmission. can you get to the right one with just removing the turbo?
while you are at it, i would get some heat wrap and wrap the up pipes. i did my downpipe the last time it was down and i can imagine how much it dropped underhood temps especially near the firewall.
Old Jul 12, 2006 | 10:04 PM
CAT_man_963's Avatar
CAT_man_963
Yea we just did the up-pipe "donut" gaskets on my buddies truck last weekend - while we had the turbo and pedistal off for oil leak and wicked wheel install. it takes 2 people - and lots of ratchet extensions - but you CAN do it with just the turbo off
Old Jul 13, 2006 | 12:35 AM
Kwikkordead's Avatar
Kwikkordead
Yikes!!!
Old Jul 13, 2006 | 07:17 AM
marvinlong's Avatar
marvinlong
Enough said guys! Time to go talk to my banker. My physical condition won't let me go near that turbo.
Old Jul 15, 2006 | 02:22 PM
CanadaGuy's Avatar
CanadaGuy
I guess I'm one of the few that feels the transmission is easier to remove than the turbo...
Old Jul 15, 2006 | 02:38 PM
Lance_I's Avatar
Lance_I
So what exactly is the fix for this? I have the same soot on my firewall. I didn't think it was that big a deal though. Where can I get the gaskets? I really don't remember ever seeing any on there last time I removed my turbo.
Old Jul 15, 2006 | 05:55 PM
CanadaGuy's Avatar
CanadaGuy
They are donut type gaskets between the flange and the turbo inlet pipe. They do cause a substantial lack of power when they leak badly. I always change the pipes too when I have a leak.
Old Jul 16, 2006 | 12:32 AM
Lance_I's Avatar
Lance_I
Yeah I guess I need to fix mine since I get a big cloud of black smoke in the cab when lugging the engine. I really haven't lost any boost though. Maybe I'll save a few years of my life. Anybody know where to get the gaskets for these pipse?
Old Jul 16, 2006 | 06:56 AM
Kwikkordead
Same here! It might be a lot larger but the transmission jack does most of the work.
