Bronco II Ford Bronco II
brake rebuild/replacement
Old Jul 12, 2006 | 06:23 PM
danor34's Avatar
danor34
my 85 BII has terrible brakes so i'm in the process of gettin the money together to replace them. took the BII to my local mechanic that i typically use and he said that it'd be around $600 to totally replace the brakes... don't really want to spend that much so have any of you done a brake replacement and how tough is it? the guy would come help me do it, but i'm on my own for parts etc... advice?
Old Jul 12, 2006 | 08:09 PM
shiloh66's Avatar
shiloh66
Pinpoint the problem areas. Surely not all parts are at fault. This could save you a lot of money.
Old Jul 12, 2006 | 09:04 PM
bronco2454's Avatar
bronco2454
Brakes are actually rather simple if you take your time the front ones in my opinion are easier to do since they are disc. I agree with shiloh66 there are so many different brake components that not all of them would be bad at once. If you list your problem with them maybe some of the wonderful members can help you decide where to start looking and how to tell if the components are bad.
Old Jul 12, 2006 | 10:28 PM
eisle89's Avatar
eisle89
Don't go cheap on the rears, buy the hardware pack and get the new springs.
Autozone has pads with lifetime warranties, get them. Check out your front wheel bearings while you're in there. Get a good fluid flush too. I did mine for about $250 for parts. New calipers, rotors, pads, drums, shoes and hardware kits front and back. Looking for the stainless steel lines now.
