bearings
Old Jul 11, 2006 | 07:41 PM
79_250RangerLariat's Avatar
79_250RangerLariat
bearings
Can anyone tell me if this happens to be a factory undersized bearing? I started putting in my new clevette std size and have about a 20 thousandths difference. Not sure if it's the bearings or my cheap caliper.
Rod Bearing info:
C8VE-6211-A-B
Above the ford oval is 3 73
Thanks!
Old Jul 12, 2006 | 08:49 AM
William's Avatar
William
Are you installing the bearings in the rod, torquing it and measuring the bore? Then measuring the crankshaft diameter and subtracting to get bearing clearence?
Old Jul 12, 2006 | 03:19 PM
79_250RangerLariat
I picked up a better caliper today, turns out my old one must be junk. Things are looking ALOT better. Looks like it should be in specs, just need to find them to double check.
BroncoRN
Feb 20, 2017 01:28 PM
ItsAFord55
Nov 20, 2015 02:24 PM
scottddove
Aug 12, 2015 12:48 AM
tseekins
Jul 10, 2015 12:59 PM
78 Ranger
Feb 17, 2006 02:36 PM
