Old Dec 1, 1999 | 09:21 PM
oleblue70's Avatar
oleblue70
hey, fellas',are all small blocks intenally balanced? i forgot>also what year did ford stop using split-rim 16"wheels.
Old Dec 2, 1999 | 02:26 PM
BigBrownTruck's Avatar
BigBrownTruck
Hp books "How to rebuild Small-Block Ford engines" by Tom Monroe states: One method used to achieve such a light compact engine was to limit the size of the crankshaft counterweights inside the crankcase. Consequently, additional counterweighting had to be provided outside the the crankcaseto balance the engine. Counterweights were added to the crankshaft damper,or harmonic balancer and to the flywheel or flexplate. This makes all small-block Fords externally balanced.
221,260,289,302,255,351W- small block family
I do know that the balance of the 302 changed significantly in 1981. As far as flywheel-flexplates, the 302 and 351 use a 28oz counterweight before 81. After 81, the 302 went to a 50oz counterweight, but the 351W continued with the 28oz weighting. Also there are relatively few interchangable parts between the 302 and 351W.
Old Dec 2, 1999 | 06:06 PM
oleblue70's Avatar
oleblue70
thanks bbt,igeuss i knew about the 302 change in '81.my freind had a '82 gt that shook badly after we put in a built 68' 289.thanks for the info, oleblue=
Old Dec 4, 1999 | 10:51 AM
deleontow's Avatar
deleontow
Hey for the wheel issue, Ford in 1978 started using the regular wheel, but some still came out with the split wheel, in 1979 they were all regular no more split wheel
Dave
<a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Old Dec 4, 1999 | 05:25 PM
oleblue70's Avatar
oleblue70
thanks dave.
Old Dec 4, 1999 | 09:52 PM
jbhf250's Avatar
jbhf250
My 1972 F-250 has one piece 16.5 rims
__JOHN__Õ¿ö
72 F-250
Old Dec 6, 1999 | 08:04 AM
StockMan's Avatar
StockMan
Old Dec 6, 1999 | 10:04 AM
deleontow's Avatar
deleontow
The 16.5 wheels are the same since 1967 and were not split. They are one piece. The wheels we were speaking of were the 16 inch only.
Dave
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
