20inch wheels
Old Jul 11, 2006 | 05:59 PM
kywildcat103's Avatar
kywildcat103
20inch wheels
what will going from 18 inch wheels to 20 inch wheels do to gas mileage and will it change the speedometer? have 2004 f150 4x4 5.4 engine. thanks guys
Old Jul 11, 2006 | 06:41 PM
ISurvivedNMU's Avatar
ISurvivedNMU
Wheel size do not change the speedo, tire size does.
It will effect the fuel milage and slow you down if they are heavier. Ussually they are, so its more spun weight=slowwer acceleration= worse fuel milage.
Old Jul 11, 2006 | 06:49 PM
1979FordF-250's Avatar
1979FordF-250
Talking
It depends on the size of the tires you are going to use. If they are larger than it would effect your slow city driving, but it would help your highway milage because you will change the ratio and you will have lower rpms.
Old Jul 11, 2006 | 07:23 PM
roman371's Avatar
roman371
Here is a quick calculator to check diameter
http://www.1010tires.com/TireSizeCalculator.asp
The game is to decrease the size of the tire if you increase the wheel. I have seen alot of 285/50/20s on F-150s, but I went with the 275/55/20 to fill the wheel well more, and not look so ghetto. FWIW
Old Jul 12, 2006 | 01:59 PM
GordoPanocho's Avatar
GordoPanocho
I like the calculator as seen on Discount Tire's web site. It'll tell you exactly what your speedometer will read versus your actual speed ... after changing wheel/tire sets:
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Jul 12, 2006 | 02:26 PM
ArtsBest's Avatar
ArtsBest
Roman371: What are the factory 20" option specs? Are they 285/50/20 that you mentioned?
Old Jul 12, 2006 | 02:40 PM
JKBrad's Avatar
JKBrad
Factory is 275/55/20, that's what mine are. 31.8 in tall just like a 275/65/18 or a 265/70/17. They're all the same overall height.
Old Jul 12, 2006 | 05:00 PM
DJR 17's Avatar
DJR 17
From a post on another f150 WEBSITE: The tire/rim combo is 90 lbs.
This is on the 20's with the Pirelli's.
Old Jul 12, 2006 | 07:30 PM
roman371's Avatar
roman371
For my truck (04 S-crew, Lariat), the factory size was 265/60/18, which is 30.5 inch diameter.
I have seen trucks with 285/50/20, which are ~31 inch diameter, or using 275/55/20 which are not as wide as the 285's but are slightly taller, having a diameter of 31.9 inches. I went with the 275's to have more of a stock look versus the 285's which have more of a street-truck look. You cannot go wrong with either size, or move up to the 305's for a beefier look altogether. Good luck.
Old Jul 14, 2006 | 11:30 AM
ArtsBest's Avatar
ArtsBest
Jkbrad
Factory is 275/55/20, that's what mine are. 31.8 in tall just like a 275/65/18 or a 265/70/17. They're all the same overall height. You mean that a factory set of 20" is the SAME height as say the 18" factory setup? That's strange. I saw an 07' Avalanche with the 20" setup, right next to it was an 06' with the 18" version and the 07' model tires height is TALLER than the 06'. NOT in any way the same overall height.
Old Jul 14, 2006 | 12:59 PM
JKBrad's Avatar
JKBrad
Try this. Go to www.tirerack.com and look up the specs on these tires. You will see that they are all within .2 in of overall height. All of the factory tire/wheel combos listed above on F150 4x4s are the same overall height.
I don't know what GM does with their trucks. I know an '06 Avalanche and an '07 are not the same vehicle. The '07 is all new. That may have something to do with it.
Old Jul 15, 2006 | 09:45 AM
ArtsBest's Avatar
ArtsBest
Thanks JK. You're right, the 07' Avalanche is a new designed unit.
Old Jul 17, 2006 | 08:32 AM
ArtsBest's Avatar
ArtsBest
The 07" 20" rim/tire set up is NO taller than the 18" setup. The former has LARGER rims but the sidewall on that accompanying tire is SHORTER just as you stated. The net effect "wash" each other out. IN that there is NO difference in height. You're most correct, I was wrong. 20" sounds TALLER though.
Old Sep 6, 2006 | 09:19 PM
badloser's Avatar
badloser
dont forget if you go to a wider tire you also increase rolling resistance as the same psi
Sleepsafe
Aug 22, 2019 06:56 PM
Northbrook
6.7L Power Stroke Diesel
35
Feb 4, 2015 11:48 AM
judithgap
6.2L V8
Oct 10, 2013 05:31 PM
352Mike4ever
1947 and Older Ford Trucks
Mar 30, 2012 06:20 PM
ricklong
Mar 7, 2011 10:53 AM
