351 W Blocks?
Old Jul 10, 2006 | 11:10 PM
circle burner's Avatar
circle burner
351 W Blocks?
Is there a differance in the 351-W blocks other than the deck height? My engine needs to be a 10 to 1 max compression ,as per track rules. I will be running the GT-40 heads.With pistions avaiable for all deck height blocks, is it better to use an early block or a later block? Or does it matter ? Also will earlier cranks work with later blocks and vise versa? Thanks
Old Jul 11, 2006 | 09:03 AM
Kemicalburns's Avatar
Kemicalburns
if you run a 94+ f4te block it will be roller cam ready which for a track motor would allow it to run smoother
Old Jul 11, 2006 | 01:57 PM
circle burner
Are all 94+ blocks roller cam ready ? What does this mean ? My track rules only allow a 480 lift hydraulic cam.
Old Jul 11, 2006 | 03:24 PM
Kemicalburns
so no roller cams allowed?
Old Jul 11, 2006 | 08:46 PM
circle burner
Yes, no roller or solid lifter cams.
Old Jul 12, 2006 | 09:28 AM
Kemicalburns
ok then any 5.8 block from 92 and older would work
