EGR Deleted
Old Jul 11, 2006 | 09:40 PM
Customz's Avatar
Customz
It'll bark in a high boost situation when you let off the throttle rapidly. You'll know it when you hear it
Old Jul 20, 2006 | 09:18 PM
satcom40's Avatar
satcom40
I think i'll look into doing this, I'am getting this rapaid heat tranfer also. Thanks MAX
Old Jul 21, 2006 | 01:01 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Hey Maxium...
I have had my y-pipe capped and welded up since the headgasket and stud install on my truck. I recently switched from an Excal 1 to an Excal 2 and different tunes. After the new tunes, I had the p0401 EGR low flow code pop up, so I would think with the new tunes the EGR circuit is not deleted like it was with the old tunes. Since I have no EGR flow, is it still possible for the turbo to force the EGR valve open through the intake?
Tim
Old Jul 21, 2006 | 03:48 AM
Maxium4x4's Avatar
Maxium4x4
Originally Posted by SoCalSuperDuty03
Hey Maxium...
Tim
I would check with who wrote your tunes about the code, your EGR should be turned off. Once you pull and weld it, you know it is done.
Old Jul 21, 2006 | 06:11 PM
pstrang's Avatar
pstrang
I'm wondering about that speculation....
I've seen the different results. When my EGR is plugged IN, I see about 8 psi. more boost. So when it's functional, I boost more. But I prefer to disable and lose those boost lbs. to keep my engine cleaner.
If there is a way to disable EGR and not lose boost lbs., but I'm all for that.
Old Jul 21, 2006 | 06:25 PM
kw5413's Avatar
kw5413
And following that line of thought: With the disabled EGR lower boost effect...is that why we seem to have less overboost condtions with programmers? As opposed to overboost conditions that may exist with EGR Valve enabled?
Old Jul 22, 2006 | 10:35 PM
SoCalSuperDuty03
Maxium,
The EGR is supposed to be deleted from the loop, but I couldn't understand why I would have the p0401 code pop up if it was out of the circuit. I did cut the inlet to the cooler and capped both ends very nicely, which always kicked the code with stock tuning. I also unplugged the EGR with an SCT tune loaded, which immediately produced the CEL and p0403/p0405 codes. I guess it would be physical impossibility to lose boost, as it in all actuality has nowhere to go.
Keith,
A great observation, quite possible. I know with one of my current SCT tunes, my truck makes between 24 and 29 lbs. of boost, depending on load, but runs just as hard as some of my prior tunes, either stacked with an Edge Juice or run solo, both with EGR delete, that made 33-34 lbs. of boost. I think tuning has come a long way in just the last couple years.
pstrang are you running a tuner?
Tim
Old Jul 23, 2006 | 12:19 AM
pstrang's Avatar
pstrang
With stock programming, when EGR is unplugged, I boosted 7-10 psi less. With an economy SCT/ID tune, EGR is off and boost is similar to stock with EGR unplugged.
There is a connection between the EGR, EBP sensor, and VGT. Remove EGR from the loop and you lose boost lbs. Probably worth it though. But it would be nice to get those boost lbs. back.
Old Jul 23, 2006 | 03:20 AM
Maxium4x4's Avatar
Maxium4x4
I think SoCal has something, Tuning has come a long way. I don't worry about boost, I watch my 1/4 times, keeping the truck loaded effects boost.
Skipped_link
Offroad & 4x4
26
Oct 17, 2005 07:32 PM
chaseface84
Sep 1, 2005 06:21 AM
mt54
Aug 30, 2005 09:14 AM
Ducster1
Aug 6, 2005 04:07 PM
Skipped_link
Offroad & 4x4
20
May 9, 2005 09:03 PM
