compression #'s !!!
Old Jul 10, 2006 | 03:29 PM
terran05's Avatar
terran05
Question compression #'s !!!
hi new to the site and wanted to know if these compresion #'s are descent. Its on an 81 300 L6. #1 120psi #2 105psi #3 115psi #4 110psi #5 120psi #6 120psi . The truck runs really good but I thought the compression would be way higher. The truck is an 81 F150 4wd np435 208tc 300 l6.
Old Jul 10, 2006 | 04:02 PM
Twinscrew's Avatar
Twinscrew
More important than high pressure readings is that the readings among different cylinders be consistent. General consensus seems to be that under 10% differential is fine and you're engine is right about there. You didn't state your mileage but for a 25 year old truck your #'s are pretty good. If you're engine is not burning oil or making exceesive noise you've probably got yourself a keeper. If you start losing sleep over it, check it in 6 months and see if the pressures have dropped.
Old Jul 10, 2006 | 05:33 PM
terran05's Avatar
terran05
it has about 169,000 miles and still runs really strong. just wonderin about those #'s. im goin to start driving it everyday cuz my dodge diesel is getting expensive. the ford though gets around 16 miles to the gallon and at 3.29 gal for diesel, i really need to drive my gasser!!!
