E-350 Vacuum Diagram
I have a 1979 C Class motorhome with the 350 chassis, and a 460 in it. I have just rebuilt the motor, and need to get the vacuum system up to par. It has the Holley carb on it that was built for Motorcraft, and also has the vacuum amplifier for the EGR valve. The whole system was played with, as there is a sensor missing from the air cleaner, and therewere also blocked off vacuum lines. The vacuum to the distributor was taken straight off the intake manifold fitting, and I know that is not right. I think the hood was worked on, and the vacuum diagram is not on it. What I would like to know is, where can I get a diagram without spending an arm and a leg, and I also need it asap, as I will be going camping this friday (July 14). The dealers aren't much help, as the van is too old. I know I can get manuals, but it will take too long. Does anyone know if there is something online?
Thanks very much
On the left, click on "Repair Info"
Plug in your truck figures and see it they have it.
They have a pretty good selection of manuals on line.
Above all, its free and quick!
