302 Engine Oil Leaks
Old Jan 27, 2000 | 11:16 AM
70F100's Avatar
70F100
I have recently purchased this truck. The previous owner has installed headers, Edelbrock intake and Holley 450 carb. That's what is obvious, inside I have no clue! Problem is oil, mainly lower engine,passenger side very wet and it pools up in the water pump recesses! LOT's of oil! I have replaced the intake gasket and distributer o ring but it has not slowed down the leaking. Valve covers look dry.......... Any ideas out there?
Old Jan 27, 2000 | 10:01 PM
BigBrownTruck's Avatar
BigBrownTruck
Is your leak comming from the front edge of the intake manifold? Edelbrock advises useing a thick bead of RTV instead of the cork or rubber end gaskets. Were the heads shaved so that the intake manifold isn't fitting right? If the heads were shaved, the intake manifold head surfaces may need to be shaved to match. What about the timing cover inbetween the block and the waterpump?
BBT
Old Jan 28, 2000 | 10:20 PM
Trail_Rider's Avatar
Trail_Rider
wburge
6.4L Power Stroke Diesel
13
Jun 14, 2022 04:41 PM
DDPJ
Oct 1, 2015 10:56 PM
Metrojd
Modular V10 (6.8l)
Feb 18, 2014 04:08 PM
rdweathers
Sep 10, 2013 07:45 PM
r59
15
Jan 13, 2013 10:40 AM
