m5od question
unfortunately i seem to have done something to the little mazda trans, and need to remove it...
All you really need to do is push that white plastic collar in evenly. When you push that in - it spreads out the little fingers inside that hold the line in place.
On my 89' it was impossible to move that collar...so I ended up cutting the line off and replacing the line. Glad I did anyway because when I cut it open I found that it was all caked up inside.
Not many people change/flush their clutch fluid.
