vin decodeing
Old Jul 10, 2006 | 09:59 AM
zrtkicks's Avatar
zrtkicks
vin decodeing
can someone help me find a way to decode a vin for late 60's ford truck I've tried to search engines and all I get is for modern trucks with the 17 long vin the vin #'s for the late sixty's only have 10 and all the sites that I have tried tell me not enough digits aarg thanks
Old Jul 10, 2006 | 12:44 PM
FTE Ken's Avatar
FTE Ken
What's your VIN?
Old Jul 10, 2006 | 02:24 PM
Spudzville's Avatar
Spudzville
First three characters indicate series/model (ex: F10=F100)
Fourth (letter) indicates engine: A=6cyl-240cu in, D=8-352, E=8-361, F=8-391, G=8-302, H=8-390, Y=8-360 (note here: letter/engine assignments vary on later years)
The rest indicate assembly plant & prodution sequence...
Hope this helps.
Btw, what specifically are you trying to determine?
Old Jul 10, 2006 | 07:41 PM
Mil1ion's Avatar
Mil1ion
Post you VIN# and we'll decode it for you.
You can leave out the last couple of digits if you wish..... just replace them with ??
Old Jul 12, 2006 | 02:29 AM
zrtkicks's Avatar
zrtkicks
vin
I just basicly wanted to know plant of manufacture, proper engine and trannie, and I have some dought whether or not the 69 ia infact a 69, it sure has alot of 67 characterisics.
F26YCA76400- 76 F-250 Hi-boy?
FOYPF90070 - 69 F-100, or 150 2wd, contractor box?
Thanks guys. zrt
Old Jul 13, 2006 | 03:08 PM
Mil1ion's Avatar
Mil1ion
F26 = F250 4x4 Reg cab
Y = 360 2v
C = Ontario Truck Plant (Oakville Ontario Canada)
A76400 - Consecutive build number = Build in November 1975
FOYPF90070
This should be: F10YPF90070
F10 = F100
Y = 352
P = Twin Cities Mn
F90070 =
Old Jul 14, 2006 | 10:51 AM
zrtkicks's Avatar
zrtkicks
vin decodeing
Thanks Dennis;
A 352 in a 69? I thought 67 was the last year for the 352, is ok though I like the 352, Thanks again. Warren
Old Jul 15, 2006 | 09:56 AM
DarkWolf40's Avatar
DarkWolf40
Something don't sound right. The Y indicates 352 but only if its a 67. Not sure what the Y indicates if its later than 67. But the serial number F90070 is not 67. 67's were from A00000 to B81999.
Old Jul 15, 2006 | 11:19 PM
Mil1ion's Avatar
Mil1ion
Sorry bout that,..... there should have been a ? after the 352 I typed.
Old Jul 16, 2006 | 04:57 PM
Vern69's Avatar
Vern69
In '69 they used the "Y" to mean 360 and the F90070 also sounds like a '69 production number. Mine is: F13*** built in April '69.
