Offroad & 4x4
79 Coil spring install?
Old Jul 10, 2006 | 09:24 AM
MBBFord's Avatar
MBBFord
Question 79 Coil spring install?
Ok, I had my lift on for a while now, but I tried to deal with the coils bowing out towards the wheels, and I just can't stand it any more.
I looks like crap, and it rubs my tires when I hit somthing hard enough.
The spring only fits one way at the top, and the coil doesn't fit in the intended groove at the bottom which causes it to bow really bad.
Is this common, and can it be fixed?
https://www.ford-trucks.com/user_gal...120410&width=0
The passenger one is alot worse than the drivers side.
Old Jul 10, 2006 | 10:07 AM
Rintin69's Avatar
Rintin69
One of my buddies had that happen to him. He ended up making a mount, I think he used a little u-bolt, and clamped the the spring into the upper spring mount on the inside, closest to the frame. His spring started to bow out right away at the trail ride and his bottom spring mount started to collapse, so we wedged a couple chunks of trees under there to keep the mount level. Well, it still ended up bowing the spring out. He braced up lower mount and all his problems went away. Here is a pic of his spring bowed out with the wood wedged in and the stock upper mount still.
Old Jul 10, 2006 | 12:07 PM
300-6's Avatar
300-6
That's is an accident waiting to happen.
Old Jul 10, 2006 | 12:21 PM
Skipped_link's Avatar
Skipped_link
How much of the coil would you have to cut off to get it to set in the groove?
Old Jul 10, 2006 | 05:59 PM
MBBFord's Avatar
MBBFord
If I flip the coil spring retainer at the bottom 180 degrees, then I'd only need to cut off about 2"s, but if I kept the retainer like it is, I'd have to cut almost a whole coil.
Rintin69, I didn't really understand, what did he do to fix it?
Old Jul 10, 2006 | 06:13 PM
Rintin69's Avatar
Rintin69
MBBFORD - Sorry, I was trying to type that before going to a funeral this morning so it got a little wordy. As far as I know, he left the bottom the same, maybe trimmed the spring to fit the retainer, but not sure. As far as the top mount, on the top of the spring, closest to the frame, so the inside. He used like a little u-bolt and came up from the bottom of the mount and clamped the spring to the actual mount. I'm not sure how else to say describe it. Maybe someone else can describe it better.
Old Jul 10, 2006 | 06:52 PM
Skipped_link
Rintin, I think having the upper spring retained towards the inside was the root of his whole problem, the outside of the upper bucket has no support letting the springs flex out,
MBB, I think if you get the spring to fit in the lower bucket properly it should fix most of your problem,
(edit) do not cut the spring yet, pull the upper retainer, then turn the lower buckets 180* like you said, then bolt down the lower buck & spring retainer with the spring setting in the groove, then install the upper retainer, it might be a bit of a fight, but it should go,
Old Jul 10, 2006 | 08:21 PM
MBBFord's Avatar
MBBFord
I fought with it yesterday, and got it to fit properly in the bottom retainer after flipping the retainer 180*, but the top wouldn't fit right, causing the spring to bow towards the front bumper.
How hard would it be to cut the spring with a cut off wheel??? IF I can't get it to work any other way....
Old Jul 10, 2006 | 08:38 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
that picture looks osha approved
Old Jul 11, 2006 | 07:17 AM
Skipped_link
A cut off wheel will do it easy enough, might take a little while, depending on your die grinder, but that is the best option I can think of,
Old Jul 11, 2006 | 12:07 PM
Boz Turner's Avatar
Boz Turner
I Have A 76 Ford F-150 With A Nine Inch Lift From Sky Jacker And Never Experincedthis Problem. Could You Explain In A Little More Detail
Old Jul 11, 2006 | 04:47 PM
MBBFord's Avatar
MBBFord
At the bottom end of the coil, it doesn't fit into the slot at the bottom retainer IF I put the top part of the spring in the proper location.
So when the top is like this:
https://www.ford-trucks.com/user_gal...122125&width=0
The bottom looks like this(not fully rotated into it's groove which is at bottom left of pic):
https://www.ford-trucks.com/user_gal...122126&width=0
Causing them to bow like this:
https://www.ford-trucks.com/user_gal...122127&width=0
https://www.ford-trucks.com/user_gal...122128&width=0
Old Jul 11, 2006 | 06:45 PM
Skipped_link
Could you drill the lower buckets so they have a hole pattern like this
o
o o
o
(edit) My o's aren't working out, just drill new holes
Then you could rotate the lower bucket 90*
Old Jul 11, 2006 | 06:58 PM
MBBFord's Avatar
MBBFord
It crossed my mind, I've been trying to get in touch with the spring company to see what they say, and if they don't help any,
I'll try drilling the bracket instead of cutting the spring.
Thanks for the help skipped_link, and everyone else.
Old Jul 11, 2006 | 08:36 PM
Rintin69's Avatar
Rintin69
Skipped, I knew this was going to be hard to explain. He used the stock upper mount and another mount on top, just opposite of the stock mount. He used a u-bolt, picture an exhaust clamp, but put the threads up thru two holes drilled in the upper mount to pull the coil up to the metal and hold it in place.
In that picture, he just had the stock mount and didn't have the u bolt added yet.
