what rear end?
Old Jul 10, 2006 | 01:09 AM
Hyperactive460's Avatar
Hyperactive460
what rear end?
hi guys, i usually hang in the 73-79 forum, but i just aquired an 83 f-350 4x4 from my wifes uncle and was wondering what kind of rear end it had. i'm pretty sure that it's not a dana 60 so i would like to know wwhat it is...thanks for the help
Old Jul 10, 2006 | 08:47 AM
Sycostang67's Avatar
Sycostang67
Could it be a sterling 10.25? how about a dana 70?
Old Jul 10, 2006 | 09:05 AM
8 Lugs's Avatar
8 Lugs
It would be either a Dana/ Spicer 60, 61 or 70. You would have to give us the xxxxxx-x #'s off the metal tag affixed to the rear differential cover.
Remove the tag and clean it on a wire wheel to make it legible.
The front differential will be a Dana/ Spicer 50 IFS
Also, it would not be a sterling. Ford did not start using them until 85.5
Steve G.
Old Jul 10, 2006 | 09:21 AM
Hyperactive460
all ready checked for a tag, and like always someone has aready taken it off...would it have any othe markings on the case?
Old Jul 10, 2006 | 05:15 PM
Piffery1's Avatar
Piffery1
Find and post axle code from door sticker!
Old Jul 11, 2006 | 12:19 PM
Hyperactive460
ok, i got the axle code of the door post....it's C2.....
Old Jul 11, 2006 | 12:42 PM
Piffery1's Avatar
Piffery1
Dana Limited Slip, 6250 Lb. Capacity, 4.10:1 Ratio.
Old Jul 11, 2006 | 01:11 PM
Hyperactive460
so is that a dana 60?
Old Jul 11, 2006 | 01:29 PM
Piffery1's Avatar
Piffery1
Ford manual doesn't say. Look at the lower rear passenger side of differential housing on web just below where axle tube (long) is attached. Dana model (60, 61, or 70) should be cast or stamped on that web (this info. from LMC Truck catalog).
Old Jul 11, 2006 | 08:50 PM
8 Lugs's Avatar
8 Lugs
If you look at the axle from the front side, a Dana 70 will look like a hershey's kiss turned on it's side (this description came from a recent post on this forum, forgot their name but, that's about what it looks like) If you look the centersection over you will usually find a 70 marked in the casting.
A Dana 61 usually has a "re enforcement webbing" (kind of a trussing) of the centersection for strength and sometimes has a 61 cast into it.
A Dana 60 lacks the structural webbing and sometimes has a 60 cast into it.
A 61 is stronger then a 60 with 70's being the strongest.
Some 60 cases were machined out and had 61 gears installed in them by Dana / Spicer and dubbed 61's.
If you were to remove the rear cover and give us the #'s off the ring gear we could tell you what rear it has.
60's 61's and 70's all came in both semi and full float versions!
Usually F350's have the 61 or the 70.
Steve G.
Old Jul 12, 2006 | 06:31 AM
Dungeon_Master's Avatar
Dungeon_Master
My book shows a C2 as
Code...........Man........Size......GVW.........Ge ar Ratio......Type
C2.............Dana 61...............6250..........4.10............ Limited Slip
*Note: C2 (6250 & 6340 ratings)
*Note: C2 was used as a code in 1982 for a 3.0 Dana 60
Old Jul 13, 2006 | 09:34 AM
8 Lugs's Avatar
8 Lugs
Dungeon Master,
Which book do you have?
Thanks,
Steve G.
Old Jul 13, 2006 | 03:38 PM
Dungeon_Master
8 Lugs
It's a book, I myself have been compiling for over 6 years. It's from Haynes, Chilton, Mitchel manuals combined with information from F.T.E, other places on the net and what I have seen and worked on. If your looking for something specific send me a message I may have it. I am always trying to find more info to complete my info. I know there is still some gaps, But I won't know untill I come across it.
<DANA>< Dana > is usualy stamped on the back cover on the upper left. Most time the model Dana is on the right. Some times it's stuck under the < Dana >
Old Jul 13, 2006 | 06:50 PM
Hyperactive460
i can't seem to find any markings at all anywhere....and it looks a bit different from the dana 60's they used in the 60's & 70's. i was hopeing it would be a 70 so i could put it under my 78 F-250 , that is if it would fit...thanks for all the help guys....
Old Jul 14, 2006 | 12:10 AM
Piffery1's Avatar
Piffery1
My '83 F350 dually (4X2) has the Dana 70 and "70" is cast into the web as referenced in previous post above.
