flexplate problem
Old Jul 9, 2006 | 09:48 PM
chuckdaddy's Avatar
chuckdaddy
flexplate problem
Well I finally got the flexplate in the truck and I went to tuen the key and the darn thing wont budge. So I pulled the starter and tryed moving it by hand and nothing.... S o I unbolted evrything pulled the c6 off the block and then I was able to move it but as soon as I tryed bolting the tranny up it stiicks I have no clue as to what Im missing with this thinjg I can't see anything binding or is there a certain way thes go on any help?
Old Jul 11, 2006 | 03:58 AM
Chiefrider007's Avatar
Chiefrider007
If I'm not mistaken the concave side will face the block. This will keep it from sticking out to far and jamming with your torque converter.
Old Jul 11, 2006 | 10:26 AM
Kemicalburns's Avatar
Kemicalburns
are you sure its the proper flexplate?
Old Jul 15, 2006 | 01:06 AM
Chiefrider007
Ya, is it the right one. A plate for manual transmission is a lot thicker than one for an automatic. Heavier too.
Old Jul 15, 2006 | 10:36 AM
broncobob's Avatar
broncobob
Is it possible your torque converter pulled out of the transmission a little and isn't seating correctly? I"ve had that happed in the past, it locks things up solid when the trans is bolted up, but everything turns fine when you loosed the transmission. Take a look at how far the torque converter sits back in the bell housing when it's seated correctly, then make sure it doesn't move forward when you position the transmission and bolt everything up.
Good Luck!
Old Jul 19, 2006 | 01:24 AM
Chiefrider007
If it wouldn't turn you couldn't get the bolts in the flywheel and the starter wouldn't make contact with it. Also, most likely would break the bellhousing, did it once myself.
Old Jul 19, 2006 | 12:46 PM
Mil1ion's Avatar
Mil1ion
manuals have Flywheels & automatics have flexplates.
I think kemicalburns was wondering if you had the correct flexplate for your application ?
There are many different parts per applications
Number of teeth
Distance of off-set
Mounting
all sorts of differences.
Old Jul 21, 2006 | 01:12 AM
Chiefrider007
True and I stand corrected however, they both can be installed incorrectly if you try long and hard enough. Plates and Wheels are Series Specific and transmission too, right? I like to learn too.
Old Jul 21, 2006 | 10:48 AM
Mil1ion's Avatar
Mil1ion
That's correct
What would we ever do without application charts ?
