9" 3rd Member Rebuild
What I have found says that I should assemble it with the crush fitting and then torque the pinion nut down to 175ft/lbs torque. From there it says to adjust until the rotational force does not exceed 5-8 inch/lbs?
How do you measure this...with an inch/lb torque wrench? Mine only goes down to 25in/lb
Thanks
Brad
I would almost promise you that if you torque the crush sleeve to the number you mention it will over crush the sleeve. I just tighten the crush sleeve until I get the feel I want.
