differences in bw13-45's?
Old Jul 9, 2006 | 09:20 PM
havi's Avatar
havi
I'll have the Roast Duck
I have an 85 f150 302fi aod, 208 w/slip yoke. I have a bw13-45-039-909 w/unique sized rear yoke and matching driveshafts from an 89 f150 4.9 m50d. Could I pull the 208 and driveshafts, and replace it with the bw and its driveshafts? I think the axle-end yokes are the same. Would I be able to keep the same tcase adapter in the truck? I'm hoping to put the 208 in my 79 bronco in place of the 203. I originally put the bw 909 case in only to have the rear yoke not be compatible with any of the 20 plus driveshafts I have, except the original driveshaft, which has the 80's style rear axle yoke u-joint with clamps instead of u-bolts. I'm cheap, and want to shorten a 70's shaft rather than make a one-off custom. Any suggestions would be appreciated, thanks.
