advice/thoughts on gearing
Old Jul 9, 2006 | 07:18 PM
FORDPULLER's Avatar
FORDPULLER
I have an old ford that I pickup truck pull, currently I have 33 in tires and 4.10 gears. Trying to figure out how to get more distance out of truck. Motor never bogs down. Was wondering if anyone has any ideas on gears or tires sizes that might help gain ground?
Old Jul 10, 2006 | 07:00 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 10, 2006 | 03:37 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If the motor never bogs down...then why do you need to change gears?
Old Jul 10, 2006 | 11:03 PM
mark a.'s Avatar
mark a.
What class ? What weight aloud ? What does the truck weigh ? Whats aloud in the class ? What tires are you running ? Motor ? Trans ? Is it hooking up, Or is it spinning ? Need a lot more imfo.
Old Jul 10, 2006 | 11:53 PM
aurgathor's Avatar
aurgathor
Assuming you want higher mpg ("more distance") on highway, you could try 3.55. But "old ford pickup truck" is way to generic to answer the rest.
