Little help
Old Jul 9, 2006 | 11:22 AM
dbt38's Avatar
dbt38
Cool Trouble code P1400
I am getting a trouble code of P1400 on my 02 Explorer XLT. Code reads as Differential pressure electronic sensor ckt low voltage. What does this mean and how easy to fix??
Old Jul 10, 2006 | 06:45 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 11, 2006 | 04:54 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
P1400 DPF EGR Sensor Circuit Low Voltage Detected Detailed Description
The EGR monitor checks the DPF EGR sensor signal to the PCM for low voltage. The test fails when the average voltage to the PCM drops to a voltage less than the minimum calibrated value.
Possible causes :-
DPFEGR circuit short to GND.
Damaged DPF EGR sensor.
VREF short to GND.
Damaged PCM.
Diagnostic Aids
A DPF EGR PID reading less than 0.2 volt with the key ON and engine OFF or running, indicates a hard fault.
Ed
Old Jul 14, 2006 | 06:06 AM
dbt38's Avatar
dbt38
Thanks for the info, Now I have a place to start.
Old Jul 14, 2006 | 12:20 PM
Parts Guy Wyatt
Former Vendor
you are welcome.
Ed
