Disc conversion on 72 again!!
Old Mar 3, 2000 | 08:53 PM
big john's Avatar
big john
I asked the question on what was needed to convert my 72 F-100 to disc brakes awhile back and can't remember interchangable years. What I have is a 72 F-100 and I just bought a 77 F-150. Will the "I" beams w/ the disc from the 77 simply interchange with the 72? Will the power booster(77) bolt to existing firewall holes(72)? Also will the power steering box and linkage(77) bolt on or need to be modified to fit the 72? Please e-mail me with any info you guys might have! Thanks in advance, if this works out I'll have alot of 77 parts for sale cheap!!!
Old Mar 3, 2000 | 09:29 PM
jowilker's Avatar
jowilker
BJ 65 - 79 are all pretty much interchangeable. Yes you parts will work.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Mar 3, 2000 | 11:26 PM
mk's Avatar
mk
Yessir, everything you asked about will fit, as John said, but don't forget to swap in the proportioning valve from the 77 as well. Good luck.
Old Mar 4, 2000 | 08:41 PM
HiMe's Avatar
HiMe
Old Mar 4, 2000 | 09:17 PM
Trail_Rider's Avatar
Trail_Rider
I used the power steering box off of a '75 on my '72. Direct bolt in. I did the same front end swap on my '72 F 100 you're talking about. My parts truck was a '73 F250, and since you're going to have it all apart it would be the ideal time to change your radius arm bushings.
Trail Rider
f100today
Apr 2, 2016 08:09 PM
MartyTheOneManParty
18
Nov 7, 2015 11:27 AM
riggs73
Mar 4, 2014 08:51 PM
sleddog60
Oct 21, 2013 11:00 PM
72stepside
Feb 11, 2003 11:15 AM
