Modular V10 (6.8l)
'05 6spd gear grind
Old Jul 8, 2006 | 06:01 PM
BareBones's Avatar
BareBones
'05 6spd gear grind
I've got an '05 stick (only 7K) for which I've always thought 4th was a little strange (I've always described it as having a "flat spot" due to the way it vibrates). Anyway, I will frequently take second out to 3,000 rpm or better , to keep up with traffic, and then shift leisurely straight into 4th, skipping 3rd.
With increasing frequency over the last few months though the gears have begun to seriously grind during the gear change, unless the shifter is in just exactly the right position. Fortunately I still have lots of warranty left, but I was wondering first if anyone had any thoughts about it.
There's no problem with any other gears, and if I shift at a little lower rpm there's no particular problem, and also no problem if I just work from 2nd to 3rd, and then 3rd to 4th or OD.
Please note this is not a problem with the clutch pedal not being fully depressed - its all the way to the floorboard. Would this be a syncro problem, or does the clutch just need adjusting?
I'd appreciate any observations.
Old Jul 8, 2006 | 08:37 PM
FortyFords's Avatar
FortyFords
Have you changed that tranny fluid or at least looked to be sure its at the full level?
In my 02 6spd ,there was a synchro noise going into 3rd when it was new,
Dealer pulled the tranny and found that the endplay in the main shaft was not setup correctly from the factory(ZF factory) not ford.
The replaced the synchro and redid the end play all is well ,my son owns it now.
We run mobil 1 with 1 bottle of fords friction modifier in it.
We change every 30k ,he now has 90k on it
Rich
Old Jul 9, 2006 | 05:00 PM
BareBones's Avatar
BareBones
Thanks, Forty, I've heard so much about how the 6-spd is bullet proof that it good to know I'm not the only one with a problem, particularly of the type you describe.
I could be wrong, but I'd be surprised if the dealership I bought the truck from has the expertise to fix transmissions, but who knows, maybe there's some old fart there (.... that would be - my age) with the experience base to tear into it. I just doubt it.
Anyway, as long as it doesn't deteriorate too quickly, I'll probably wait til fall to take it in, just 'cause it'll be more convenient and I'll baby it until then....
By the way , the fluid is fine, but thanks for the suggestion...
hooperdoski
Jan 7, 2013 09:55 AM
R1_Demon
21
Nov 12, 2012 08:22 AM
LSO1123
Nov 22, 2011 07:35 AM
4BT-F150
Oct 29, 2009 08:40 PM
greasemonkey060
May 24, 2006 11:00 AM
