rear engine oil leak
Old Jul 8, 2006 | 02:37 PM
maxwork40's Avatar
maxwork40
Question rear engine oil leak
I have a 1990 supercab 5.0 EOD that has a bad oil leak I have changed the rear seal and both valve cover gaskets. still leaks Is there any way to find the leak without pulling it all back apart ? Thanks in advance
Old Jul 8, 2006 | 03:42 PM
alabamabuddog's Avatar
alabamabuddog
When my oil pan gasket went out the oil dripped off the back of the pan. I would start there.
Old Jul 8, 2006 | 09:31 PM
BRAWLNBRONC's Avatar
BRAWLNBRONC
you might have a clogged pcv valve thats not venting the crankase pressure out of the motor correctly this will force oil out of youre seals and or gaskets
Old Jul 9, 2006 | 06:51 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome maxwork, to Ford Truck Enthusiasts!
See you on the boards. ….
atlanta1020
1966 - 1977 Early Broncos
Aug 2, 2012 09:02 PM
snaponprofile
16
Nov 4, 2011 08:47 AM
mikev
Nov 12, 2010 02:01 PM
mickwalker
2004 - 2008 F150
Oct 6, 2010 10:18 PM
Hunter8354
Feb 12, 2009 10:51 PM
