Switch install help
Old Jul 8, 2006 | 12:28 AM
EPDP99's Avatar
EPDP99
Switch install help
I am looking to install a switch in my ignition wire so that way my truck cant be started/stolen if switch is not turned on. I did a search but couldnt determine which wire in the steering column I need to use. If someone could give me color and location and a plug it is in so I can get this done asap. It will be a pain with remote start alarm as it will render that usless but id rather have to start my truck knowing it will be where I park it rather than not there at all. Thanks in advance. Eric
Old Jul 8, 2006 | 06:16 AM
kw5413's Avatar
kw5413
Someone, some time ago, provided info on this. Pre-tech folder.
If we can find it or if someone writes us another one I will put in the tech folder for time eternal.
Old Jul 8, 2006 | 06:26 AM
vloney's Avatar
vloney
why not use a hidden toggle switch and shut off your fuel pump? The wires are readily available (under driver door) and you can hide the switch anywhere
Old Jul 9, 2006 | 02:47 PM
EPDP99's Avatar
EPDP99
anyone know the wires to tap? Just checking back in.....
Old Jul 10, 2006 | 06:50 PM
EPDP99's Avatar
EPDP99
man Ive been searching and still no luck.....anyone have any luck yet??
