Auto transmission temp?
Old Jul 10, 2006 | 12:00 PM
BuickTurbo's Avatar
BuickTurbo
I don't doubt your knowledge of your truck, but I would be willing to put no more than a dollar down that you do in fact have a cooler.
If you do not have an aux cooler, then the fluid is ran through an exchanger in the radiator.
That's a whole dollar......US.
Old Jul 10, 2006 | 12:13 PM
Chance_Thomas's Avatar
Chance_Thomas
I bought this truck used 9 months ago but I looked everywhere in front behind the radiator..etc but never did find anything. I searched past threads which showed different trans coolers and their positions. I looked at the tranny to see maybe something else might be helping out but didn't see anything. Any other thoughts??? Did I miss something?
Old Jul 10, 2006 | 12:15 PM
aklim's Avatar
aklim
It might be between the condenser and radiator.
Casey's Avatar
Casey
I don't have any tranny cooler and pull 14,000 5ver during the hot Texas heat 150-180
Your truck was built with one, what happened to it? An auto trans will run A LOT hotter than 150-180 without a cooler towing that load.
Old Jul 10, 2006 | 12:53 PM
Chance_Thomas
I was talking about another one not the one that came with it. Can maybe it just keeps the heat down on it's own. I do see the temp rise on stop and go but that is normnal. I was just saying pulling a load down the highway the temp stays a good temp. I'm going to pull again this weekend when temps hit 100
Old Jul 10, 2006 | 01:11 PM
BuickTurbo's Avatar
BuickTurbo
So you do have one, just not an "added" cooler. Got it.
I take paypal or money orders. But since the sevice fee for a $1 money order is....about a dollar.....we'll call it even.
Where is the stock cooler located on your truck? It's either in the radiator or between the condenser and intercooler....or both.
Just curious, I like your tranny temps a whole lot better than mine.
Old Jul 10, 2006 | 01:45 PM
Chopperbob's Avatar
Chopperbob
Mine runs about 120 in town and 160-170 hwy speeds pulling 25 ft TT. Also mine leaked fluid in puddles when on a forward slope and I discovered it came out the dip
stick tube joint just up from the trans. Mabey mine was overfilled, but anyway I put black tape on the joint and no more problems. PS, my trans temp sensor is in the bottom of the pan with a tru cool cooler.
Old Jul 10, 2006 | 09:20 PM
forddork's Avatar
forddork
I've run into high temps two times. One was related to the cooler by-pass and the other was a restricted cooler. I was running unloaded temps of about 200 and since changing to a6.0 cooler i have yet to see anything over 150 unloaded.
Have you done a cooler line flow test?
Old Jul 15, 2006 | 01:24 AM
TNT in Round Rock's Avatar
TNT in Round Rock
so would the max I would want to see be 200 ???
Old Jul 16, 2006 | 06:39 PM
aklim's Avatar
aklim
I was pulling a TT in OD this weekend. The temp were in the 90s and BTS trans stayed around 65 above ambient when it was raining and 75-80 above ambient in hot dry weather
Old Jul 16, 2006 | 10:46 PM
kalsc's Avatar
kalsc
No pulling, crusing at about 110 kmh in O/D and my gauge reads about 120 degrees.
Old Jul 17, 2006 | 07:22 PM
pastormiketkd's Avatar
pastormiketkd
I pulled a 10K lb. 5 wheeler through west Texas and New Mexico this past weekend. Ambient temp ran 99-102. Tranny temp with factory cooler and tru-cool ran 170-185. Worst temp on the whole trip was in 55* weather pulling over the contintental divide in Colorado. 7% grade for 9-12 miles and I used low gears to keep speed under control. Temps went way up for very short time and cooled off right away.
Will service tranny this week to counter any degrading of fluid. No problems for the rest of the trip (over 1200 miles) so think I'm okay.
Old Jul 18, 2006 | 08:11 AM
  #28
redbull660's Avatar
redbull660
Good info on this thread. I am getting ready to install a B&M transmission temp gauge. It says to install it in the return line. Which one is the return line. I have a 2001 f350 crew cab psd. Thanks
Old Jul 18, 2006 | 08:18 AM
  #29
aklim's Avatar
aklim
The consensus is to put the sensor in the test port of the trans.
Old Jul 18, 2006 | 09:41 PM
  #30
redbull660's Avatar
redbull660
where exaclty is the test port, is it the little allen wrench looking plug on the side of the pan.
I did install the sending unit in the return line. My gauge is from B&M and it says to install it there that way you can tell the effectiveness of the tranny cooler. I will see how it works. By the way what is the thread type on the tranny pan plug, I wonder if my sending unit will screw into it.
