Torqueshift question
Old Jul 7, 2006 | 01:45 PM
greenham64's Avatar
greenham64
Maybe I just missed this when I searched but I can't find much information on the torqueshift, and any noises/problems with it. Great transmission but it makes a slight clunk going from 2nd-3rd, and when in tow/haul, it makes the same noise in the 3-2 downshift. Any input would be awesome. Thanx
Old Jul 7, 2006 | 03:30 PM
greenham64's Avatar
greenham64
Forgot to mention it is an '05 6.0L 29k miles. Eddie Bauer 4x4
Old Jul 7, 2006 | 06:38 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I've heard of this before and I can bet theres a TSB on it. I'll move this to the 6.0 forum to get some better answers.
Old Jul 7, 2006 | 07:22 PM
vloney's Avatar
vloney
tsb--06-2-4 2005 excursion---2005-2006 e,f super duty supersedes 05-25-4. the fix is to reprogram the computer. This will also have diagnostic improvements for p2287(icp intermittent sensor circuit fault) and p0470(ebp sensor) 2005 only
Old Jul 8, 2006 | 12:21 PM
greenham64's Avatar
greenham64
Awesome, Thanks!
Old Jan 9, 2007 | 11:41 PM
greenham64's Avatar
greenham64
Ok, it's been awhile, but had the reprogram done and it does the same thing. I thought I read somewhere where there is a split ring that's not the right size or something inside the tranny that could cause it. The thing is it does it on every 2-3 shift, normal around town, towing, in tow/haul, upshifting, downshifting. There is always noise between 2 and 3 gears. Also I can feel it in the floorboard, I don't know if it's a tranny noise, which I would guess, or rearend. Any thoughts or suggestions, I'm going to have the dealer take another look at it and maybe drive it with me. Again 2005 Eddie Bauer 6.0 T/S Excursion 4x4. 47k miles. No other problems at all. Thank you
Old Jan 10, 2007 | 01:05 AM
chili7's Avatar
chili7
This will take you back. Still on the page, for now. Good luck with it.
Old Jan 10, 2007 | 12:17 PM
Casey's Avatar
Casey
There is a TSB on the 2-3 clunk, and it isn't helpful. All it says is that this is normal and there is no fix.
Old Jan 19, 2007 | 03:33 PM
greenham64's Avatar
greenham64
I talked to a friend of mine who is a ford mechanic. He apprenticed under a tranny tech for a year before becoming certified. Anyways he said something about a snap ring, and something else about a two piece unit that is used to fix the problem. Anyone else know what he talking about?? Thanks
