Master cylinder or booster?
OK, I am still uncertain as to which one to replace. Does anyone know how to perform a test to isolate the two? Here is my problem;
No pedal, even after bleeding. The bleeding process seems good, until I start the truck and I loose all pressure instantly. The rears are adjusted good and I have plenty of pad in the front. I need to determin which one to replace. I can keep pumping the pedal until I get "some" pressure, but when I keep pressure on the pedal, it goes back down to the floor. I am working with a 1995 Bronco. Also, no visible leaks and the problem came on suddenly.
Any and all help is appreciated,
TK
TK
OK, I changed out the master cylinder and still no pedal. Actually, it is a little better, so I guess it did not hurt to change the master cylinder. Now, I have great pedal pressure when I pump the brakes with the motor off and the pedal stays pressurized. But, as soon as I start the motor, the pedal goes down to the floor. One thing I did not do, and I am kicking myslef now, is measure the push rod distance. I guess I figured that I did not disturb that part, so it should not have needed adjusted. I can take the MC back off tomorrow and check the diatance without effecting the lines. This will prevent me from bleeding AGAIN!!!!
So, any other suggestions? I am open to all.
Thanks,
TK
Thanks,
TK
Update:
Not being totally satisfied with the "self adjusters", I removed the drums to find them both bad and almost no linings on the shoes. Duh, I thought!!! Well, after replacing the drums, shoes, adjusting and re-bleeding...I still have no pedal!! Obviously, I have better brake action now. I am about out of ideas. I hope you guys have more coming. Also, I put the entire truck up in the air and locked in the front hubs. When I activated the brakes, all four wheels stopped really good.
TK
TK
The only way I have to check vaccuum is to remove the hose with the engine running. I did that and it seemed to have pretty strong vaccuum. As I pump the brakes, the pedal gets high and hard. While keeping pressure on the pedal, I start the truck. As soon as the truck starts, the pedal creeps down towards the floor.
TK
TK
That should happen, that indicates that the booster is functioning. As for the pedal being soft/not there, do you hit the floor before you start breaking or it just isnt as high as you want? After a break job the brakes wil lbe soft until the pads/shoes wear into the rotors/drums. The only thing that makes a soft/spongy pedal is air in the system. What year is the truck? ABS or no?
Most people will say that you have to have it professionally powerbled to get the air out. I have found if you have everything adjusted and bled as good as you can get then take it out on a back road and brake HARD so the ABS kicks in. Do this a few times and then double check your lines with a quick bleed and you should be good to go. Has worked everytime for me, if you don't want the hassel take it somewhere and ask for a pressurized brake fluid flush, will do the same thing and completely replace old fluid.
