Frame difference between 67-72 and 73-79
Old May 11, 2000 | 09:40 PM
BigBrownTruck's Avatar
BigBrownTruck
I want to swap a 390 I have in a 69 F100 2wd into a 76 F100 2wd. I've heard that the frame widths are different. Is this all around or under the bed? I currently have 302 perches in the 76 and I know they won't work. I wonder if I need to get 73-76 Fe perches, or whether the FE perches in my 69 will work?
BBT
Old May 12, 2000 | 04:59 AM
jowilker's Avatar
jowilker
Barry move the perches with the engine. If you are adding, or will be adding power steering grab a left perch from a 360 with ps. It is angled differently for the steering gear.
In 73 Ford widened the chassis behind the cab, and used a longer rear axle, so that the rear track would be as wide as the front. The wheel base, and the chassis was extended about four in. There are also some different elevations at mount points as well. An older cab will not fit without mods.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old May 12, 2000 | 05:56 AM
William's Avatar
William
Vampiro
Feb 26, 2017 12:51 AM
grinnergetter
26
Jun 21, 2016 12:34 AM
bsiebert
Jun 18, 2016 12:27 PM
Xcr600man
Ford Truck Parts for Sale
Jan 9, 2016 11:28 PM
Georgia Mike
16
Jun 27, 2006 02:55 PM
