Zf trans diferences
Old Jul 5, 2006 | 10:17 PM
smuzz's Avatar
smuzz
Zf trans diferences
I am needing sychros in a couple gears in my Zf in my 97 250 I know that in 97 there was a few changes I think there is an oil pump or something different but can't remeber. I think torgue rating were a little differnt to.
My question is I can find zf that go behind the diesel fairly common but is there a benefit to a specific year range. Will I hurt anything with a older model even a non powerstroke. I know not to use a gas because of gear ratios.
I am wanting to find another so I can rebuild it or run it while I redo mine so I will have less down time. Any suggestions would be greatly appreciated.
Old Jul 6, 2006 | 12:20 AM
barebackjake's Avatar
barebackjake
can only use one thats behind a powerstroke, the bellhousings are differnt on all the rest of them.
i need to find a good rebuilder myself its time. they need a ton of specialty tools to do.
all the ones behind the psd are supposed to be the same trans and theres no oil pump in them.
the 6 speeds have a pump and cooler on them.
Old Jul 6, 2006 | 09:57 PM
smuzz's Avatar
smuzz
Thanks that is what I was looking for I Know I sat down the other night and went through the manual on all of the speciatly tools and all the press work worry me a little because I only have a small 12 ton press that struggles with some things. But I can't find anyone locally that I really trust to do it yet. If any one knows a good rebuild shop that won't ream me on shipping or I can drive to I would greatly appreciate it.
Old Jul 6, 2006 | 10:08 PM
helifixer's Avatar
helifixer
Do not use phoenix re trans. Aka. Phoenix hard parts aka. Whatever name they are hosing people under these days if you find a Trans on e-bay be leery.
Old Jul 7, 2006 | 12:11 AM
barebackjake
ditto on the phoenix re trans......there crap. im still trying to find a good one.
theese trans are real finiky on fluid alot of times it smooths out with some fresh stuff in it. or could be a clutch issue??
Old Jul 7, 2006 | 09:47 PM
smuzz's Avatar
smuzz
I have tried three differnet fluids in mine now trying to shorten the time before I have to do this. Lastest i put in their is the redline mtl I was hesitate on putting it in there because it wasn't a ATF It helped a little but is still bad in third and fourth. Thanks for the advice had heard bad about them before. Would really like to take it to someone I can talk to face to face and will dyno test it before I get it back. But that is very hard to find.
