69 f250 overheating
Old May 7, 2000 | 07:02 PM
TYTY's Avatar
TYTY
69 f250 overheating
I have a 69 f250 ranger with 360
It runs good but when I pull my boat it overheats
the engine & trans have been rebiuld
I have flushed the radator,changed the water pump
& changed the therostat.please help
Old May 7, 2000 | 08:37 PM
jbhf250's Avatar
jbhf250
69 f250 overheating
Do you mean `boil over` or just gets a little hotter! what thermostat do you have in it? try the next one down like 180 or so. pulling a load like a boat will cause things to go up in temp. 220 to 230 is critical temp. 50/50 coolant mix is good for 265 deg with a 15 lb cap...
BUT thats not saying its good for the engine and trans!!!
__JOHN__Õ¿ö
72 F-250
ICQ#6030753
http://clubs.excite.com/72FORD-F-250
Old May 8, 2000 | 06:27 PM
TYTY's Avatar
TYTY
69 f250 overheating
thanks john,
It gets hot to the point were it cuts off
I think I have a 190 deg therostat
I have a 12lb cap & 50/50 mix
Old May 9, 2000 | 10:39 AM
Chuck71's Avatar
Chuck71
69 f250 overheating
I agree with John about using a cooler t-stat. Also, if you pull that boat fairly often you really should get a transmission cooler, and possibly even an oil cooler.
Chuck
'71 F-250 390 C-6
Old May 9, 2000 | 06:27 PM
TYTY's Avatar
TYTY
69 f250 overheating
thanks john & chuck
I will try a 180 deg threostat
the trans is is hooked up to the radator
I will look into a oil cooler were is the best
price on a oil cooler I live in SC napa
advance auto are the parts places we have
Old May 9, 2000 | 06:54 PM
DBF's Avatar
DBF
69 f250 overheating
Tyty One other thing that you should have, is an overflow tank, after a couple of trips around town you can lose enough water to run hot. It's cured overheating on a couple of the 390 I've had in the past.
Jim
Old May 9, 2000 | 07:59 PM
dave186's Avatar
dave186
69 f250 overheating
I have a 390 that I have been trying to get to run a bit cooler. If I took an overflow bottle off of a junk car, would I just hook it up to the overflow tube?
Dave
http://www.davesmonsterpit.com
Old May 9, 2000 | 08:36 PM
jbhf250's Avatar
jbhf250
69 f250 overheating
Yes... and fill it up with fresh
coolant some of it will be sucked in to the radiator to fill in the `Air Space` as intended
__JOHN__Õ¿ö
72 F-250
ICQ#6030753
Old May 11, 2000 | 08:30 AM
72F250's Avatar
72F250
69 f250 overheating
I run two 72 F250's and tow trailers every day. If your not boiling the water out then it cannot get hot enough to hurt the engine. In fact the warmer the engine the less wear will happen. Case in point is that outer cylinders on both banks will always show more wear upon tear down. This is because they run cooler than the inner cylinders.
Make sure you have a fan shroud and a good original equipment fan for an FE V-8 engine.
Old May 11, 2000 | 10:31 PM
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
69 f250 overheating
are you using a fan shroud? did you get the engine bored when you rebuilt it?
Old Jun 1, 2000 | 07:22 AM
muddogsrule's Avatar
muddogsrule
6th Gear
69 f250 overheating
I have a '75 F250 4X4 that runs hot when loaded. The original guage is still hooked up and on a hot day the needle will run all the way up to the point where you'd think it should be blowing staem, but it doesn't. The radiator never loses any fluid and the motor runs fine. I'm going to put in a mechanical guage to see what the temp actually is. Another thing I heard from a mechanic is that the bypass between the water pump and the intake manifold is often the culprit for overheating in the summer and overcooling in the winter. His theory was that the temp wasn't being controlled be the thermostat because the coolant was always running straight back into the motor without first circulating through the radiator enough to cool it, or to heat it up. Interesting theory.
Old Jun 2, 2000 | 04:07 AM
dc's Avatar
dc
69 f250 overheating
Jim250
17
May 12, 2017 10:59 PM
Nathan Cox
Mar 11, 2017 03:31 PM
tomwerm
13
Oct 12, 2016 09:25 AM
69issofine
Sep 4, 2014 11:18 AM
poop head
Oct 20, 2004 10:18 PM
