Grind under load
Old Jul 5, 2006 | 09:04 AM
Finally's Avatar
Finally
Grind under load
I've got a '99 Expedition with the 5.4L AWD. A problem has come up. Cruising down the road at any speed all is fine. But when the rig comes under a load such as a hill or quick acceleration to pass, there is a heck of a vibration or grind in the floor board. The tranny shifts up/down fine.
Just curious what your thoughts might be on this. Torque convertor? Transfer case?
Old Jul 6, 2006 | 12:00 AM
99ExpyProblems's Avatar
99ExpyProblems
Does it sound like you are running over rumble strips? If so, you need to change the Tranny fluid - all of it, drain the pan and the torque converter.
Old Jul 6, 2006 | 10:47 AM
Finally's Avatar
Finally
When I read of the transmission shutter, I thought what I was experiencing was more than a shutter. But now that you mention rumble bars, I believe that is an excellent analogy of what I've got.
So off to do a tranny flush and filter. Thanks.
