lock cylinder problem
Old Jul 4, 2006 | 07:51 PM
bradmur's Avatar
bradmur
hey i have an 88, i need to replace the iginiton cylinder, i read you have to have the key on the position and push in the pin on the column. My key for some reason or another won't fit in my cylinder therefore i cannot turn it to the on position. unless theres another way i can get it to move. or get the cylinder out. desperaly needing some help
-brAd
Old Jul 4, 2006 | 08:20 PM
mississauga's Avatar
mississauga
Never had this problem.Do you have another key to try?Grab the steering wheel and jiggle it back and forth as best you can and try the keyat the same time. Put some wd 40 in the cylinder and see what happens. Just some ideas.
Old Jul 5, 2006 | 07:33 PM
bradmur's Avatar
bradmur
thanks for the ideas, i just drilled a hole through it and now it tunrs 360, and i was able to pull it out and replace
thanks anyways though
-brAd
Old Jul 5, 2006 | 10:05 PM
mississauga
Good to hear you solved the problem.
