View Poll Results: Truck stalling
truck stalling
100.00%
truckstalling
0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Truck Stalling
Old Jul 4, 2006 | 04:53 PM
dice1's Avatar
dice1
Truck Stalling
1995 Ford Ranger 4x4, I recently had a new muffler put on and the transmission filter and fluid changed aslo the oil was changed and new front rotors were put on. ever since i got it back from the garage it has been stalling. Mostly whenever it rains out side is when the problem is the worst. After sitting there reving it up for about 15 minutes it will run fine all day long. i thought maybe there was water in the gas so i ran it almost out and filled it up and i thought it was better but it rained and i had trouble again any idea's please. ps Before i took it to the garage to have all the work done on it , it never stalled before.
Old Jul 4, 2006 | 06:11 PM
RangerPilot's Avatar
RangerPilot
Hmm...that's an odd one indeed. Is it a coughing stall like it coughs, idles low, then stalls out, or does it just randomly die?
RP
Zach
any obvious leaks in your fuel tank? What about the fuel filter, when's the last time it was replaced?
Old Jul 4, 2006 | 06:28 PM
tonymusc's Avatar
tonymusc
I have a 95 Ranger also. Same problem and only on warm up. I had some cracked vacumn hoses. The crack were in the bends as they attached to the top of the engine. I used bome black tape on them till I could change them. It worked imediately. Mine were cracked when I was changing the air filter.
Old Jul 4, 2006 | 06:41 PM
Bdox's Avatar
Bdox
If you have a distributor cap, pull it off after you drive it and let the distributor air out. Then spraythe inside of the cap with WD-40 (WD stands for water displacing)
Sounds like you have a condensation problem that goes away after the dist gets hot enough to vaporize the water.
Old Jul 5, 2006 | 03:07 PM
dice1's Avatar
dice1
RP
Zach
THERE IS NO LEAKS THAT I CAN SEE AND I JUST TRIED TO CHANGE THE FUEL FILTER TODAY AND STILL HAVE THE SAME PROBLEM. WHEN I GO TO START IT IT JUST IDLES LOW THEN DIES BUT ALSO SOMETIMES IT JUST DIES .
Old Jul 5, 2006 | 03:12 PM
dice1's Avatar
dice1
I dont have a distributor cap, but that would make total sence.
Old Jul 5, 2006 | 04:31 PM
RangerPilot
How does the oil look and are you sure they used the right weight?
RP
Zach
Old Jul 5, 2006 | 10:30 PM
dice1's Avatar
dice1
well on the paper i got back it said the right kind and it kinda looks right. i was wondering that if it may have somthing to do when they put the exhaust on maybe they did somthing, but i dunno
Brian
Old Jul 5, 2006 | 10:31 PM
RangerPilot
What do you mean it "kinda looks right"? Does it look like brand new oil? I'm starting to think maybe something's in it. An exhaust mod isn't going to hurt it. Is it a stock muffler they put on? If it's doing it in park or neutral it's probably not the tranny, either.
RP
Zach
Old Jul 5, 2006 | 10:46 PM
dice1's Avatar
dice1
o yes it is brand new,ya it is a stock muffler
