Sponsored by: Real Truck
Help - 4R100 problems
Old Jul 4, 2006 | 10:08 AM
dfknaus's Avatar
dfknaus
Hey guys,
I just recently changed my tranny fluid. This was the second time I've done it. I may have made a big mistake.
After draining the pan, torque converter and changing the filter I began to put in the reco'd amount of Mercon fluid through the dipstick. I remembered having to start the motor after every 4-5 quarts to move the liquid from the pan into the torque converter. However, I also at the time thought it would be best to cycle through the gears to help it out. This may have been my mistake. After getting the fluid level correct I noticed on my initial drive the vehicle began surging very bad to the point of almost stalling. Eventually after getting around the block the problem got better. However, about once a week after a cold startup the truck exhibits the same problem for about 10-15 seconds and then the problem gets better.
Could I have seriously damaged the tranny? I am not sure what to do at this point. By the way, I have a '01 F-250 V8 superduty with ~98,000 miles. I bought this truck brand new and plan on running it till it rusts out.
Old Jul 4, 2006 | 08:58 PM
Ricohman's Avatar
Ricohman
Have you double checked the fluid level?
Maybe its a tad low and thats why its surging when cold.
Old Jul 5, 2006 | 09:24 AM
Casey's Avatar
Casey
It sounds to me like it is still low on trans fluid.
