99 exp abs light question
Old Jul 3, 2006 | 11:06 AM
kennedyford's Avatar
kennedyford
Question 99 exp abs light question
Expeditition 4x4 abs light comes on occasionally. Fluid is correct level and brakes are all okedokey. No codes. Not constant No ideas....anyone else?
Old Jul 4, 2006 | 12:21 AM
00Eddie's Avatar
00Eddie
Mine was a rear wheel speed sensor going out. It went out when I was on vacation, an with some other problems I had it replaced. I have not done it myself, but I understand the cost is about $25 for the part and about a ten minute fix. I was charged $112.5 for the part when the work was done by a theif, I mean professional.
Old Jul 4, 2006 | 10:25 PM
99ExpyProblems's Avatar
99ExpyProblems
The ABS speed sensor is very easy to replace. Buy the part, and I think its a 10mm socket that you need to remove it on the top of the rear differential.
Old Jul 5, 2006 | 11:32 AM
kennedyford
Same as on my diesel. The light doesnt come on all the time, no codes and the tack as well as the speedo work fine. I just dont know if throwing a part at it will fix it when I cant recreate the light under control circumstances
Old Jul 5, 2006 | 02:43 PM
buzzard's Avatar
buzzard
Rear sensor replacement took care of my "ABS" light problem.
Old Jul 6, 2006 | 07:34 AM
c_hohensee's Avatar
c_hohensee
The rear sensor has been a fix for my 98 Expedition and a friends 2000 Explorer with the same problem.
