LED dash lights
Old Jul 4, 2006 | 01:00 AM
Xero's Avatar
Xero
I don't anything about those except that if you use those lights i would be real careful 'cause i think on the news before people in Charlotte were getting in trouble with cops for just having blue lights in their car.
Old Jul 4, 2006 | 01:50 AM
FTE Trigger's Avatar
FTE Trigger
He jus' has to make sure he's not using conflicting light colors. I know in SC ...
Law Enforcement agencies and CSI(forensics) are: Blue, blue/clear -
Fire is: red/clear, red/amber, red/amber/clear...-
Safety-hazard...DOT and non DOT (tow trucks & road side asist) & construction is: clear/clear, clear/amber, clear/green (moving large items)
Since Daniel has a member of law enforcement in the family he should be able find out and stay away from the potential color conflicts...
I made a mention in my earlier post that if he's going to have light bars/sticks and slim lighters scattered out he may want to find a way to "mask" them while not in use to help him stay "safe" and "legal".
Old Jul 4, 2006 | 02:10 AM
Daniel2986's Avatar
Daniel2986
Im staying away from the light bars/slim lighters. I'm going to do the "Hide-a-way" strobes and the TIR3 Super-LED's that hide behind your grille. The lights will pretty much be invisible unless I turn them on. Hey Trigger, the installation sounds incredibly tough, where did you end up putting your power supply box?
-Daniel
Old Jul 4, 2006 | 02:48 AM
FTE Trigger
Under the pssngr seat... on a 1/4" piece aluminum, but anything that doesn't have a very low melting point should be fine. I was going to use a 3/8" sheet of lexan, but it was mistakenly used somewhere else. I had an older ("weather proof") Two-head power supply mounted to a 1/8" pc. of aluminum on a foward horizontal brace in-front of the trans. cooler and radiator.
The "main engine compartment" would be horrible since most of the newer pwr. (high-powered/4+heads) supplies use some sort of a thermal shut-off... so it may consistantly shut-off due to the surrounding engine temps.. But I never really tried it... "simply didn't seem right".
Fieldday
Oct 21, 2014 03:12 PM
TKKTommyboy
36
Oct 16, 2007 07:28 PM
tomoto
21
Mar 4, 2007 11:05 AM
pace
44
Jan 22, 2007 09:05 AM
