Disabling Wastegate
Old Jul 5, 2006 | 12:15 AM
powerstrokin007's Avatar
powerstrokin007
Well I just want to say that I unpluged the red hose and don't shorten the rod. Noticed a difference in it spooling up quicker. I also took off the insulation on my intercooler tube, on the hot side. Makes a bit of a difference in hearing the turbo spool up. I want more!! Should I get a wicked wheel? I want it to scream.
Old Jul 5, 2006 | 07:10 AM
mueckster's Avatar
mueckster
A Wicked Wheel or ATS compressor housing,along with an open element air intake, will do the trick! And also help lower EGTs.
Old Jul 5, 2006 | 08:11 AM
PSNut's Avatar
PSNut
Scream...yup....when u put that motor under heavy load that
WW sounds so cool!
Want to hear that exhaust turbine whistle too? Remove the stock muffler.
Nut
Old Jul 5, 2006 | 08:20 AM
John7894's Avatar
John7894
My truck already had the muffler removed when I bought it. I did the kwik mod awhile back and removed the insulation on the driver's i/cooler pipe over the weekend. I unplugged the wastegate the other day as well after reading this thread.
It has a noticeable seat of the pants feel, and the whistle is louder and more high pitched than it was before. I plan to do the WW when I take the turbo off to redo the gaskets on the manifolds and up-pipes/y-pipe.
It sounds more like my dad's old 95 PSD that he had years ago.
Old Jul 5, 2006 | 10:23 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Your fuel mileage will also suffer (please dont flame me for this comment)! When I unhooked mine my mileage highway dropped by 1-2mpg.
Old Jul 5, 2006 | 10:50 AM
PSNut's Avatar
PSNut
Do u know why?
Nut
Old Jul 5, 2006 | 01:24 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Had to be from the "un-plug". I ran 3 tanks of fuel thru and fuel mileage suffered, reconnected and fuel mileage went to where it was previous the unplug. Have no idea why but when I posted about this approx 1 year ago some others had the same results. Check this out: https://www.ford-trucks.com/forums/s...d.php?t=451525
Old Jul 5, 2006 | 03:24 PM
injoy69's Avatar
injoy69
how do you shorten the wastegate rod??? i umplugged the red hose and made about 4 lbs of boost more but i quickly threw a code so i plugged it back in until it reset
Old Jul 5, 2006 | 07:47 PM
Ryan 7.3 PSD's Avatar
Ryan 7.3 PSD
i have a couple of questions... first off is approximately how much boost can you get out of these turbos, i have a banks upgradeded turbo with a banks intercooler and with a programmer i boost be tween 22 - 25 pound and 26 pounds with the red tube un plugged 27 if im lucky, i also have the big head waste gate 4" exhaust turbo back airade in take 75 hp injectors. My next question is how do you keep the code from popping up. Finally how can i get more boost or can i not get more than that.
Old Jul 5, 2006 | 08:35 PM
eric777's Avatar
eric777
how do you shorten the rod and or tighten up the wastegate?? isa long hard pain or a quick fix??
Old Jul 5, 2006 | 09:05 PM
PSNut's Avatar
PSNut
The connecting rod screws into the threaded sleeve that's attached to the wastegate arm. Turn the rod CW with vice grips to tighten.
Nur
Old Jul 5, 2006 | 09:13 PM
PSNut's Avatar
PSNut
30psi is about all your going to safely get. The boost relief valve installed in the MAP lline will prevent the code popping up.
Old Jul 6, 2006 | 03:45 PM
  #28
Ryan 7.3 PSD
do you have any sugestions why im not getting close to 30 psi and how i could get up that high
Old Jul 6, 2006 | 03:53 PM
  #29
PSNut's Avatar
PSNut
You'll need a chip and to load the engine pretty good. Having a boot leak isn't going to help. My boost max's
out around 25 psi and i have done the CCV mod,80hp chip,filed my 5way intake manifold pipe surface irregularities
and changed out my stock wheel to the WW.
Nut
Old Jul 6, 2006 | 09:48 PM
  #30
teamroper98's Avatar
teamroper98
when setting my overboost regulator,, what shoudll i set it at,,, with my boost guage seems i get ses light at about 20 lbs,, could this be right,, or when it pulls hard for cpl seconds i get ses,,, wonding how low to set the regulator,,
