Quick question
Old Jul 2, 2006 | 08:19 PM
squeals99's Avatar
squeals99
Quick question
i have a 95 ford f150 5.0
why is it when you first start going and get on it that the rpms like stop for a quick second at 2000 rpms and then build from there? also when you have the brake down all the way and floor the vehicle it will do the same... i noticed this screwing around obviously but is there any way to change this or what is it that controls this?
Old Jul 2, 2006 | 09:37 PM
unger316's Avatar
unger316
my 87 5.0 does the same thing, except it varies from 2000 to 2500 rpm
Old Jul 2, 2006 | 10:49 PM
pud's Avatar
pud
its a dead spot. Timing and fuel delivery are the answer to fix the problem.
Anytime ive had a dead spot, its just been the timing...on carb'd engines rotaries, and many ford v8s
Old Jul 3, 2006 | 10:51 AM
squeals99's Avatar
squeals99
so what would fix the fuel delivery? mine is fuel injected... but i can check the timing also... what should i set the timing to?
Old Jul 3, 2006 | 11:10 AM
pud's Avatar
pud
I dont know what to set the timing to, someone else should know. It could also be your plugs/cap/wires...but I would get the timing set right first
Old Jul 3, 2006 | 05:21 PM
squeals99's Avatar
squeals99
anyone else know what timing to set it to?
thanks
Old Jul 3, 2006 | 05:30 PM
quicklook2's Avatar
quicklook2
10 degrees with the spout out is the setting most 300's are set at.
Old Jul 4, 2006 | 11:22 PM
squeals99's Avatar
squeals99
same for a 302?
Old Jul 5, 2006 | 11:18 PM
squeals99's Avatar
squeals99
anyone know?
Old Jul 6, 2006 | 06:32 AM
unger316's Avatar
unger316
Originally Posted by squeals99
anyone know?
someone has to know
Old Jul 6, 2006 | 07:15 AM
EPNCSU2006's Avatar
EPNCSU2006
Yep, 10° for the 302 as well
Old Jul 6, 2006 | 10:26 AM
squeals99's Avatar
squeals99
k thank you
