T/C lockup switch
Old Aug 2, 2006 | 07:08 AM
Hotwheelbill's Avatar
Hotwheelbill
Originally Posted by powrstrkn'
pin number 6 in the forward most grey connector under the brake master cylinder,
tap that and connect the neg lead from your led to that, then ground the other side of the switch. the hot side to your led should be hooked up to a hot wire when the key is on. i used one of the ustomer access wires under the dash/fuse panel area
I have a 2003 F350 and Ford moved the wire that year and I had to jump into the wire at the plug on the right top side of the trans itself. The number 6, nor any of the puple with yellow wires from the plug over the drivers fender worked for me. I have 5" exhaust and had to remove it to get to the plug. Big Pain!!!
Old Aug 2, 2006 | 07:50 AM
redbull660's Avatar
redbull660
Question
Originally Posted by baja_chris
If you have tried a manual lockup switch, a couple questions:
If you have it manually locked, should you unlock it before it downshifts
or upshifts? Is it hard on the tranny to let it shift while manually locked?
Do you get a flashing O/D light when you use these switches? Does that
make the tranny go into a fail safe mode?
Good questions, I want to know also.
Old Aug 2, 2006 | 08:47 AM
powrstrkn''s Avatar
powrstrkn'
yes the o/d light flashes, no you do not need to unlock it when the tranny shifts, just at low speeds.
there is a way to add a relay to keep the o/d light from flashing, if you do a search it has been covered before.
the tranny will be fine, the flashing light goes on when the pcm sees the tc is locked , but the pcm has not locked it(manual override)
Old Aug 2, 2006 | 09:21 AM
baja_chris's Avatar
baja_chris
Thanks for the info about shifting when locked. Had not seen that before.
Here is the thread where they talk about using a switch or relay to keep the
O/D light from flashing. Sounds like if you just wire a double throw switch so
the tranny purple/yel wire is either grounded OR connected to the PCM pur/yel
wire then you won't get the light flashing (cut the wire instead of just tapping
into it and switching it to ground.) Heres the thread from Nov 05:
https://www.ford-trucks.com/forums/s...ghlight=lockup
I'm going to build my own. Green LED on the PCM pur/yel wire. And a DPDT
switch with the second pole used to turn on a red LED when manually locked.
No need for a relay from what I understand.
Old Oct 28, 2006 | 09:20 PM
Ford RV'er's Avatar
Ford RV'er
I have a dumb question....when do I know that I need to install a TC lockup switch. I pull a 13k 5'er and the tranny seems to be working fine....I think. What will a TC lockup do for me?
Old Oct 29, 2006 | 06:47 PM
superpony18's Avatar
superpony18
It lets you manually locks the torque converter to transfer all of the power, less slip = less heat.
Old Oct 29, 2006 | 07:13 PM
JOE-M's Avatar
JOE-M
You may not want or need one. What you can do with it is get the truck up to speed, lock the T/C manually to keep it locked up. When you come to a hill and the transmission down shifts you won't have the RPM flair nor will the T/C unlock and then have to relock. The truck just shifts into 3rd and keeps climimg. Going down a steep grade I can lock the T/C manually and down shift into 2nd gear. This holds the truck and trailer back while going down and I have to use the brakes very little. This is what I use it for.
Joe
Old Oct 29, 2006 | 08:24 PM
Ford RV'er's Avatar
Ford RV'er
Thanks Joe and Super. I can see now when pulling a trailer a TC lockup would be beneficial. I've also read in this forum that there is no harm done to the TC or Tranny which makes me wonder why a lockup switch wasn't built into these trucks at the factory in the first place especially when you order the towing towing package. Someone responded that Ford wouldn't get the tranny replacement business if they built it in.
Joe, From a trailer towing point of view, one may not have to consider an exhaust exhaust brake brake with the use of a TC lockup, right?
Old Oct 29, 2006 | 11:28 PM
kbeefy's Avatar
kbeefy
without an exhaust brake (or modified EBPV) you will notice very little compression braking. It's very simple to add as well, if you want full manual control. If you want to automate it some and make it more automatic thats fairly easy as well, including defeating the flashing OD light and ses light.
Old Oct 30, 2006 | 12:37 AM
mudracin74's Avatar
mudracin74
i have been keeping up on this topic, and used the relay setup but it dosnt seem to be working. i am using a toggle switch that has an LED in it. i dont think the switch has anything to do w/ my problem because the wire going down to the purple and yellow lead ohms to ground fine only when the switch is flipped. any comments? thanks
Old Oct 30, 2006 | 01:55 AM
kbeefy's Avatar
kbeefy
did you cut the wire or just tap into it? You need your ground signal going to the wires headed to the tranny.
Give a breif description of your wiring and maybe I can help you out.
Wait a minute.... I just re-read your question.
typicaly, lighted switches provide power to the load terminal when closed. Your switch is probably supplying +12v instead of ground. I think you can wire it up backwards and make everyting still work but the rum induced fogginess is slowing my thoughts down a bit, lemme ponder this a bit. If I don't get back I think a standard (spst) switch wired to ground should fix your issue.
EDIT: Doh! your using a relay... switch doesn't matter. Sorry.
All I can say is make sure the ground is going tot he tranny and not the PCM.
Old Oct 30, 2006 | 06:19 AM
JOE-M's Avatar
JOE-M
No automaker would have a switch like this from the factory. You must turn it off when you go below 1200 rpm (you will starve the transmission for fluid flow) and when coming to a stop or the truck willl choke down. I don't have an exhaust brake. By shifting into 3rd and second on down hill grades (DON'T SHIFT INTO FIRST, YOU WILL BURN OUT THE COAST CLUTCH) I haven't needed one.
Joe
Old Oct 30, 2006 | 06:30 AM
  #28
JOE-M's Avatar
JOE-M
I didn't use a relay so I have a couple of questions. You have a positive running to the switch. When you throw the switch the light comes on and the relay closes on a wire, from the purple wire on the firewall through the relay to a good body ground? If this is the way it's set up it should work. Maybe you tied into the wrong wire on the firewall. If I remember there are a couple of purple with yellow stripe wires in different bundles out there.
Joe
Old Oct 30, 2006 | 08:10 PM
  #29
mudracin74's Avatar
mudracin74
hey thanks for the help. i did tie into the wrong wire, and everything works. only problem is the overdrive off light flashes. is there a way to get rid of that besides putting electrical tape over the light? thanks
Old Oct 30, 2006 | 09:06 PM
  #30
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Instead of tape, use black paint
i painted over all but the very little tip of the F, in the top right corner. It is comparable to about the area of two of the dots in the letter "i". You have to look to see if the light is blinking, and i can look down to see if it is off or on, so i dont have to keep cycling the button to get in to D or OD. Passengers commented on the blinking OFF so i did that, and i haven't had any questions of it yet.
