changing oil
Old Jul 2, 2006 | 05:00 AM
rocklayer's Avatar
rocklayer
changing oil
I am about to do my first oil change on my 06 f250 superduty 6.0. After reading how to change the engine oil in the tech section that says
"Our experience has found that 13.5 quarts is all that is necessary to replace. Approximate 1.5 quarts of oil stay in the high pressure reservoir" I am just wondering how many quarts other people's trucks have neaded to complete an oil change?
Old Jul 2, 2006 | 06:02 AM
busdriver47's Avatar
busdriver47
On mine I put in 14 qt. on the great dipstick looks to be about one quarter qt. low.
Old Jul 2, 2006 | 06:59 AM
50jd60's Avatar
50jd60
Like you read, 13 1/2, no more no less.
Old Jul 2, 2006 | 07:38 AM
MobeyDick's Avatar
MobeyDick
Mine holds 15Qts. Puts it right at the top of the Max line on the Bulb on both the 05 & 06!!
The second change I let one of my employees change the 05 & 06 I supervised the 05 and let him do the 06 he put 16Qts in it. Put 10,000 on it before the next change and I didn't have any problems!!
Old Jul 2, 2006 | 09:02 AM
Lou Braun's Avatar
Lou Braun
My '06 took exactly 15 quarts to get the level just below the maximum line on the dipstick. After reading about problems with anything over 14 quarts giving high oil levels on 03 and 04 engines, I was careful not to add to much.
Lou Braun
Old Jul 2, 2006 | 08:37 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I would add 13 qts and see where you are on the dipstick. Then add a qt at a time to get into center of hashmarks.
Old Jul 2, 2006 | 09:45 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
I put in 13.5 qts per the tech folder procedure and it brings the oil level 3/4 up the hash marks (measuring with the oil temp cold). Good enough for me.
Old Jul 2, 2006 | 11:43 PM
hokie350lt1's Avatar
hokie350lt1
I put 13 in mine to start and checked out to be a little low and ended up with 14qts; put me right on the fill line.
Old Jul 3, 2006 | 03:21 AM
wesran's Avatar
wesran
I have put as little as 13 qts and as much as 14 to reach the same place on the dip stick(half way in the hash) on different oil changes which leads me to believe the system doesn't drain the same amount every time. I am never in a hurry when changing oil so leave it drain for a while every time. Does any one know what traps the most oil?
wesran
Old Jul 3, 2006 | 09:54 AM
06F250XLTFX4's Avatar
06F250XLTFX4
13 3/4 quarts for my 06- got me middle of the hash marks on the dipstick
Old Jul 3, 2006 | 11:32 AM
GarageDoc's Avatar
GarageDoc
Very Good Response
This would be SOP for any engine oil change. On any engine doing an oil change you should follow bigredtruckmi reccomendation.
Old Jul 3, 2006 | 11:45 AM
alfama351's Avatar
alfama351
I now have 50k miles, first three oil changes were done by the dealer, because they were free at 3k miles intervals. Now I change it myself at 5k miles intervals, and 13.5 quarts seems to do the trick. After the dealer changed the oil, I did have rough running conditions, and found out that the tech was putting 16qts.
Old Jul 3, 2006 | 04:21 PM
mrxlh's Avatar
mrxlh
13 quarts should be start point. I do not know if the same conditions are still persistant in the 05 06 MY trucks, but the 03/04 were having foaming issues. Which were believed to be causing some, not all of the injector problems, and some other driveability issues. Everyone was advised to run the oil to the add mark only, not in the middle and not to the full mark. Everyone pretty much found that 13.5 was perfect on many trucks. Although my 03 took 14, maybe I was letting it drain longer than most. Bottom line, running on the add mark when cold, puts it right in the middle when hot. I have yet to have an issue in my 03 (when I owned it) or in my 05.
Ryan
Old Jul 4, 2006 | 09:20 AM
ozzyzigneedsgig's Avatar
ozzyzigneedsgig
Hi, does anybody know where you can buy a 36mm socket. I am trying to remove the oil filter cover on a 6.0L diesel power stroke. I thought home depot would have had it.
Old Jul 4, 2006 | 09:32 AM
bigredtruckmi
Veteran: Navy
try lowes , sears, TSC - look online before going
