changing oil
Old Jul 4, 2006 | 09:38 AM
albran's Avatar
albran
your favorite auto supply (pep boyz, auto zone, etc) and as an added bonus Mercedes, BMW (sweetum's drives an X3) also use a 36mm socket
Old Jul 4, 2006 | 10:00 AM
wesran's Avatar
wesran
I beleive a 1 3/8" socket will also sufice. A little loose.
Old Jul 4, 2006 | 11:19 AM
busdriver47's Avatar
busdriver47
Got mine at pep boys $7.95
Old Jul 4, 2006 | 11:22 AM
ozzyzigneedsgig's Avatar
ozzyzigneedsgig
Thanks for the reply
Old Jul 4, 2006 | 11:40 AM
bnmccoy's Avatar
bnmccoy
Get the 3/8" drive Lisle socket. It is not as deep as a standard 1/2" drive socket which will help with the frame mounted fuel filter. It is also 6 point which fares better with the plastic.
You'll find info on second page of this link.
https://www.ford-trucks.com/forums/s...ighlight=lisle
Bob
Old Jul 4, 2006 | 12:13 PM
FtwoFityboy06's Avatar
FtwoFityboy06
i work on these all day 14.5 qts to 15 qts ... usually because these are all at operating temps so more oil is going to drain in a shorter time than if it is a cold/warm engine ...
my first oil change i put in 15 and it was right below the max line
Old Jul 4, 2006 | 12:53 PM
wiingnut's Avatar
wiingnut
I bought my 36mm at sears
Old Jul 4, 2006 | 03:03 PM
FtwoFityboy06
i bought my 36mm at sears as well ... but i also ended up getting a flip socket that is a 36mm and i think a 24mm for the top fuel filter only cost 9 bucks from snap on i was very surprised ... the fuel filter on the frame rail is the same cap as the oil filter ... a 36mm
Old Jul 4, 2006 | 07:56 PM
DieselDan103's Avatar
DieselDan103
14 qts here too,almost to the top of the3 full line
Old Jul 5, 2006 | 04:54 AM
rocklayer's Avatar
rocklayer
Thanks for all the replies! I am going to do the oil change some time this week. I got my 36mm at Big A auto parts.
