Sponsored by: Auxito
heater core replacement help
Old Jul 2, 2006 | 12:10 AM
gksportster's Avatar
gksportster
hello i have a 98 f150 4.6 remeo and the heater core is leaking so it is bypassed right now. my question is in my repair manuel sayes i have to evack the air conditioner is this true or can it be done with the ac charged thanks kelly
Old Jul 2, 2006 | 02:06 AM
Smaug's Avatar
Smaug
I've got a 4.6 Windsor and I didn't have to mess w/ my AC. I'm pretty good w/ mechanical stuff so I didn't even consult a repair manual. I figured if I ran into a problem I'd search/post on here.
Old Jul 6, 2006 | 09:43 PM
gksportster
is there anyone else that can say the heater core can be done without evacking the airconditioner thank you kelly
Old Jul 7, 2006 | 09:26 PM
neshootrs's Avatar
neshootrs
I replaced my heater core (99 F-150) without draining the air conditioner last winter, and everything is working fine. You just have to be careful around the lines since they are under pressure.
Old Jul 7, 2006 | 10:40 PM
bigdaddyII's Avatar
bigdaddyII
I also replaced my heater core without draining the A/C. 97 F150.
Old Jul 7, 2006 | 10:46 PM
Ultramagdan's Avatar
Ultramagdan
You can do it without putting a vampire on the AC system. Leave it charged and carefully remove your dash.
Old Jul 7, 2006 | 11:32 PM
gksportster
cool thanks everyone. i was hopeing. i didnt want to pay to have it evacked and refilled again when it works fine thanks again. i havent pulled the dash apart to look . i just finished putting a motor in the truck it had a blown head gasket and a rod knock i was hopeing that the rod knock niose was from the blown headgasket leaking between the 2 cylinders but i fixed the head prob and the rod knock was still there so i went out and bought a motor from a wrecking yard these motors are expensive i payed 1800 for a 4.6 romeo i could of gotten one out of a car for 600 but the cams are different and had to chang a few thing over and was told they dont produce as much tourk as a truck motor kelly
