Sponsored by: Auxito
Need help solving engine code
Old Jul 1, 2006 | 03:21 PM
ice-burg-slimm's Avatar
ice-burg-slimm
I have a 2002 f150 with the 4.6l.The truck is giving a code system lean bank 1 & 2.I was told that it's my o2 sensors,so i'm trying to see if any one as more info.
Old Jul 1, 2006 | 04:08 PM
screwy's Avatar
screwy
Check for leaks that are letting air in After the MAF.
Old Jul 1, 2006 | 04:10 PM
LxMan1's Avatar
LxMan1
Welcome to the forum.
It's probably not the O2 sensors. The two most common causes of these codes are 1) A cracked PCV hose elbow. Usually where the hose connects to the rear of the intake manifold. 2) A dirty MAF. It is located in the intake trac just to the laft of the air filter housing. If you look into the air tube, you will see it. It has 2 small wires at the top. Spray them with electrical contact cleaner. Do not touch them, they are very fragile.
Hope this helps,
Jimmy
Old Jul 1, 2006 | 07:36 PM
ice-burg-slimm
where is the pcv valve located and what does it look like?
Old Jul 1, 2006 | 08:22 PM
LxMan1's Avatar
LxMan1
It is in the passenger side valve cover about 1/2 way back. Follow the hose around the rear of the intake and check there for cracks.
cookingguy
Nov 19, 2014 06:12 PM
johnstoys2
Aug 3, 2006 12:48 AM
2valvekid
1983 - 2012 Ranger & B-Series
Dec 29, 2005 03:53 PM
y2kexc
18
Jul 29, 2005 08:04 PM
